TNGO 使用二维条形码读码器建立了 LED 灯条跟踪和追踪系统
TNGO, a machine builder that has supplied luminance inspection machines to major Korean LED production facilities, has integrated the Cognex DataMan® 100X and 100S, as well as the In-Sight® Micro 1110 into their LED luminance inspection machine to create an automated part history management system with a track and trace system. This successful system has now been installed in nine LED production lines.
Superior read rates at high speeds
TNGO’s LED-bar luminance defective inspection moves along 30 meters with 5 stages of testing. Each plate has 16 bars and each bar and plate has unique barcodes to verity that the test is being properly performed by each stage.
In the LED-bar luminance test, in particular, products move rapidly, and diffused reflection is severe because of the intense vibration. Because of the environment, a barcode reader which guarantees high read rates even under variable work conditions was required by TNGO. In addition, the bars are close together so TNGO needed a compact barcode reader that could be installed in a very small place and could tolerate a small field of view in which to search for codes.
The Cognex DataMan 100 series is an ultra-small, fixed-mount reader which integrates lighting, camera, processor, and communication functions. This product is perfect for production facilities which require the greatest performance in a very limited space. It was the first choice for starting TNGO’s parts history management system. The DataMan 100X presents the highest read rates under any circumstances such as code deformation. DataMan 100X offers the powerful 2-D decoding software, IDMax® ,and offers superior performance capable of handling all codes from 1-D/2-D barcodes to the most difficult Direct Part Marked (DPM) codes. This model has exhibited the best performance in reading the end user’s ECC 0 2-D Data Matrix code (17x17).
Mr. Kim Jae-gwang of IDINTECH, a Cognex ASP (Automated Solutions Provider), said ,“The DataMan 100X is a high-performance, ultra-small product with a capacity of handling 60 frames per second and up to 45 decodes per second. Because it enables USB and RS-232 communications as well as a PoE (Power of Ethernet) connection, it is very convenient in system integration.” He also said, “While other companies still use a 1-D scanner for LED history management system, TNGO has adopted the DataMan high-performance 2-D reader in consideration of compatibility and extendibility in the future, which has made it possible to provide better solutions.”
Contribution to the improvement of work efficiency and productivity
Meanwhile, TNGO has focused on enhancing the productivity of the history management system by integrating the DataMan reader with an In-Sight Micro 1110 ID vision system. The combination of Cognex products has made it possible to read four LED-bar barcodes at the same time it is being inspected using the In-Sight Micro at the final stage of the luminance. This has maximized the speed and efficiency of the entire process.
The In-Sight Micro ID reader, which features high-tech OCR/OCV tools and 1-D/2-D code reading and identification software, enables character and barcode reading at the same time.
Jae-gwang said again, “Unlike the manually operated conventional history management system, the Cognex vision solution-based automated history management system has enhanced work productivity up to three times.” He added, “Because additional facility investments continue thanks to high demand for LED products, it appears that the demand for a history management system would increase accordingly.”
About TNGOTNGO has accumulated great knowledge and technology in the automation of manufacturing facilities in the semiconductor and display industries, the automation of various testing and inspection facilities and manufacturing equipment & system integration solutions. The company now develops and provides LED module in-line automated inspection equipment, high-temperature lighting inspection equipment, low-current lighting inspection equipment, and manual LED module inspection systems with diverse solutions in automation. The company started under the name of Ai-OS ENG in 1992 and was renamed to TNGO in 2004. For more information, visit their website (http://www.tngo.co.kr).
公司名称: 康耐视中国
联 系 人: 市场部
电  话: 400-008-1133
传  真: 021-32091980
地  址: 上海浦东新区外高桥保税区泰谷路207号一楼D1座
邮  编: 200131
该厂商相关解决方案:
康耐视的Checker传感器确保瓶装检测的正确无误
全程质量跟踪确保西门子汽车业客户长期保持高满意度
康耐视的视觉系统保证更好的瓶装技术
TipTop冰淇淋的完美包装
Checker™ - 以100个工件/秒的速度实现完美无暇的标签检测
康耐视:复杂视觉应用的唯一解决方案
康耐视PatMax™- 适用于机器人应用环境的统一解决方案
康耐视视觉系统简化了激光焊接技术
康耐视实现外科植入物完全自动化检测
康耐视 In-Sight使汽车装配时间缩短了20%
对2000种不同的断路器实现百分之百的可靠检测
更多方案...
立即发送询问信息在线联系该解决方案厂商::
