Ãû ³Æ£ºÆµÆ×·ÖÎöÒÇ
ÐÍ ºÅ£ºHP 141T
³§ ¼Ò£ºÃÀ¹ú»ÝÆÕ
ÏÖ ÊÛ£º18000Ôª
¼ò ½é£º10MHz-18GHz
HP 141T 8555A 8552B 8553B ƵÆ×·ÖÎöÒÇ
´ø¿í: 10MHz - 18GHz
·Ö±æÂÊ : 100Hz - 300KHz
Frequency/Division : 2KHz - 200MHz/Div
Signal level : -125dBm to +10dBm
Max input level +10dBm
Dynamic range : +30 dBm
Sweep time : 0.1uS - 10 S/div
Input 50 ohms / type N connector
»ÝÆÕ(°²½ÝÂ×)HP 141TƵÆ×·ÖÎöÒÇ £¬ÆµÂÊ·¶Î§ 10MHz - 18GHz¼ÓMIXER¿É´ï43GHz¡£ÄÚÖÃHP8555A RF¸ßƵ½ÓÊÕÄ£¿é¼°HP8552B¸ß·Ö±æÂÊÖÐÆµÄ£¿é¡£
The 141T Spectrum Analyzer System features absolute calibration of frequency and amplitude, high resolution and sensitivity, wide dynamic range, and simple to interpret display output. Four plug-in tuning sections (all sold seperately) utilize a wide range of plug-ins and permits measurements at frequencies ranging from 20Hz to 18GHz (to 40GHz with external mixer). Features an easy to read 8 x 10 cm variable persistence CRT with a writing rate from 0.2 s to 15 s. Maximum storage time is over 2 hours at reduced brightness. The modularity of this system allows you to keep pace with changing measurement requirements. Plug-ins sold separately.
