ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
ºóÃæ°å
³§ÉÌ: ÃÀ¹ú»ÝÆÕ/°²½ÝÂ×
ƵÂÊ·¶Î§ 252kHz - 2060MHz
ÐÔÄÜÖ¸±êpdf
The Agilent 8645A agile signal generator combines high performance with frequency agility for new fast-switching test requirements. These capabilities are important for performance testing of such devices as frequency agile radios and surveillance receivers. Besides extending traditional receiver testing to agile applications, the Agilent 8645A can be used to create complex signal simulations involving several modulation types and frequency agility. The high performance and frequency agility of the Agilent 8645A provide capability for both static and agile test requirements with just one calibrated signal generator.
- High performance in-channel and adjacent channel measurements, both in static and agile operation
- Simultaneous FM, AM, and pulse modulation
- Maintains signal performance while switching frequencies as fast as 15 microsec from 128 to 2060 MHz
- Flexible control of frequency switching using GPIB from the front panel or TTL connectors from the rear panel
ÌøÆµ¼¼Êõ¼ò½é , ÌøÆµÍ¨Ðżò½é
¶þÊÖ»úÏÖ»õ£¬È«Ð»úÒÑÍ£²ú£¬Ìæ»»»úÐÍ E8257D
µç»°: 010 - 62123258 / 62123259 ÓÊÏä: buy17@163.com
