µ÷ÖÆÓò·ÖÎöÒÇ HP 5373A
³§¼Ò£ºÃÀ¹ú»ÝÆÕ
ÔÖµ£º$39,720
Ïêϸ²ÎÊý(PDFÎļþ) [¿´PDFÐè°²×°Èí¼þAdobe Reader]
¼ò½é£º
ƵÂÊ·¶Î§£º8kHz - 2GHz
µ¥´ÎƵÂÊ·Ö±æÂÊ£º10λ
ʱ¼ä¼ä¸ô·Ö±æÂÊ£º150ps/1ps
Á¬Ðø²âÁ¿ËÙ¶È£º13*10+6
´æ´¢Æ÷ÈÝÁ¿£º8000
Ö÷Òª¹¦Äܼ°Ó¦Ó÷¶Î§£º¶Ôµ÷Ƶ£¬µ÷·ù¼°Âö³åµ÷ÖÆÐÅºÅµÄÆµÂÊÎȶ¨×´Ì¬½øÐй۲졢²âÊÔ¡¢·ÖÎö
²å¼þ chA:HP 53702A Envelope Detector. 20 dBm MAX,50¦¸
chB:HP 54002A µã»÷¼ûÏêϸ²ÎÊý£¨PDFÎļþ£©
The 54002A is a 50 ¦¸, BNC input pod for oscillosopes and
waveform analyzers.
125 mHz to 500 MHz with channels A and B. Fast time-interval histograms, pulsed measurements, and envelope measurements. HP-IB.
Frequency range: 8kHz to 500MHz. Frequency resolution: 10 digits. Time interval resolution: 150ps/1ps. Option 030: 2GHz Channel C.
5373A Modulation Domain Pulse Analyzer
The Agilent 5373A modulation domain pulse analyzer provides built-in functions for pulsed signal analysis and is ideal for applications requiring radar and EW signal characterization. It minimizes design and testing efforts required for modern military, air traffic, marine, weather, and space-based radar systems. The measurements of phase, frequency, and time are optimized for complex signal modulations.
The 5373A simplifies the study of agile carriers, staggered PRI, chirp, phase coding, and similar modulations whether intentional or unintentional. The 5373A analyzer is particularly suited to working with pulsed and non- repetitive signals. It measures modulation and carrier frequency on pulsed RF signals to 500 MHz, and includes a detector channel for precise measurement of envelope parameters such as pulse width and PRI, peak envelope power, percent AM, jitter, and more.
200 ps single-shot, Least Significant Digit (LSD), 10 digits/second for frequency measurements (2 ps LSD for averaged measurements)
Broad selection of measurements, arming and triggering configurations
Built-in analysis, including math, statistics, limit testing, and calculated Allan Variance
Graphic display and histograms for added visual meaning from collected data
Up to 13 million measurements per second, 500 MHz frequency range (expandable to 2 GHz with optional channel)
For complete product specs, click on the Data Sheet link.
