Êý×ִ洢ʾ²¨Æ÷ TEK 2432
³§¼Ò£º ÃÀ¹úÌ©¿Ë
This unit is a 300MHz digital storage oscilloscope with 1Kb memory, automatic measurements, an on-line help function, an output for a printer or plotter, and a scan speed from 5nS/div to 5sec/div.
2432 Performance Characteristics
Form Factor Benchtop
Bandwidth 300 MHz
Number of Channels 2 ch
Simultaneous Channels 2 ch
Simultaneous Maximum Sampling Rate/ch 100 MSa/s
One ch. only max. sampling rate 100 MSa/s
Max. Single Shot bandwidth 40 MHz
Max. Record Length 1024 pt/sec
Min. Vertical Sensitivity 2 mV/div
Maximum Vertical Sensitivity 5 V/div
Rise time 12 ns
Number of Bits 8 bits
Input Impedance 1 MOhm
Input Impedance (alternate) 50 Ohm
Input Coupling AC,DC,GND
Maximum Input Voltage 400 Vrms
Maximum Input#2 (for Impedance #2) 5 Vrms
Main time base - lowest 5 ns/div
Main time base - highest 5 s/div
Timebase accuracy .0015 %
Trigger Source Internal
Display Type CRT Monochrome
Display Size 12.7 cm
2432 Programmability/Connectivity
User Interface Proprietary
Ports to Peripheral Devices GPIB
Programming Language GPIB
External Video Out No
2432 Compliance
CE Compliance Not on file
UL Compliance Compliant
2432 Power Requirements
Input Power Universal (Auto Sense and Switch)
2432 Physical Dimensions
Width: (N/A)
Height: 190 mm(7.48 in)
Length: 479 mm(18.85 in)
Weight: 10.9 kg(24.03 lb)
