ÎóÂëÒÇ PCM Monitor 34-8 EPM08
²úµØ:µ¤Âó
Receiver input-Rx(CCITT rec.G.703)
Bit rate:34368 kbit/s 8448 kbit/s
Max. dev:¡À100ppm ¡À100ppm
Line code:HDB3 HDB3
Cable att:Max.12dB Max.6dB
Vin(peak):1.00v¡À10% 2.37v¡À10%
Gain:0 db or 26dB,selectable for both bit rates
Transmitter output-Tx(CCITT rec.G.703)
Bit rate:8448 kbit/s 2048 kbit/s
Max. dev:¡À30ppm ¡À50ppm
Line code:HDB3 HDB3
Vout(peak):2.37v¡À10% 2.37v¡À10%
Recharge input 24v (DC)
Recharge voltage:24V DC
Recharge time:16 hours
Technical Information
External Clock:
Internal Printer:
IEEE 488:
RS232:
Other Information: 75 ohm Impedance; Combined transmitter and receiver
Footnotes:
H x W x D: 6 x 12 x 24
kg: 1
Code Types
RZ:
NRZ:
CMI:
AMI:
HDB3:
Injection
Single Errors:
Fixed Rate Errors:
ITU-T Rec.
G.703:
G.704:
G.821:
G.826:
Jitter
Transmit:
Receive:
Measurements
BER:
BLER:
%EFS:
Alarm Seconds:
Frame Alignment / Alarm:
Code Errors:
Frame Errors:
No Signal:
AIS:
Pattern
PRBS:
Word:
PDH Data Rates
704K:
2M:
8M:
34M:
140M:
Variable/Other:
