ÎóÂëÒÇ PCM Monitor 140 EPM09
²úµØ:Denmark(µ¤Âó)
Receiver input-Rx(CCITT rec.G.703)
Bit rate:139264 kbit/s(rec.CCITTG.703)
Max. dev:¡À100ppm
Line code:CMI(rec.CCITTG.703):
Cable att:Max.12dB at 70MHz(rec.CCITTG.703)
Vin(peak):1.00v¡À20%
Gain:0 db or 26dB,selectable
Transmitter output-Tx(CCITT rec.G.703)
Bit rate:34368kbit/s(rec.CCITTG.703)
Max.dev:¡À20ppm(rec.CCITTG.703)
Vout(peak):1.00v¡À10%
line code:HDB3(rec.CCITTG.703)
Recharge input 24v (DC)
Recharge voltage:24V DC
Recharge time:16 hours
