Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú PCMÐÅÁî¼à²âÒÇ EPM11
²úÆ·Ãû³Æ£º PCMÐÅÁî¼à²âÒÇ EPM11
ÐÍ ºÅ£º EPM11
Æ· ÅÆ£º µ¤Âó GN Elmi
PCMÐÅÁî¼à²âÒÇ EPM11
³§¼Ò£ºµ¤Âó GN Elmi
Ìå»ý£º43x18x33cm
ÖØÁ¿£º13 kg
ÅäºÏ ZTFK 76215£¬¿ÉÓÃÓÚ£¬µçÁ¦ÏµÍ³Êý×Öµ÷¶È½»»»»ú¼ì²â£¬²âÊÔ·½·¨
The PCM Signal Monitor is an instrument for in-service monitoring of the two PCM links forming a first order PCM communication system. The instrument is used for testing CCITT recommended 30/31-channel PCM systems at various levels of the exchange hierarc.
Der PCM Signalmonitor dient der ¨¹berwachung der beiden PCM Verbindungen eines PCM Systems erster Ordnung. Es ist zum Test von 30/31- Kanal PCM Systemen nach CCIT ausgelegt. Verschiedene Ebenen mit unterschiedlichen Kodes werden untersucht. Das Ger?t besitzt zwei identische Eing?nge zur ¨¹berwachung und Messung der relevanten Parameter. Die Bit- Rate betr?gt nach CCIT G.703 2048 kbit/s 100ppm. Zur akustischen ¨¹berwachung des Telephonkanals ist ein Lautsprecher eingebaut.
The PCM Signal Monitor is an instrument for in-service monitoring of the two PCM links forming a first order PCM communication system. The instrument is used for testing CCITT recommended 30/31-channel PCM systems at various levels of the exchange hierarchy where different codes are used. Two identical inputs for monitoring * of the signal and alarm conditions; * of frame alignment signal error rates * telephone channel signal (8bits) * the signalling (4bits) * the channel time slot 0 and 16 and for measuring of the * frequency of the incoming bitstream * telephone channel signal peak code * telephone channel signal analog level * analog output of the telephone channel signal * audible output of the telephone channel signal Various LEDs monitor conditions and detect errors Bit rate of the input channel is: 2048 kbits/s 100 ppm; built- in speaker for supervising the telephon channel.
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
