Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú HP4934A/JO2 ´«ÊäËðÉ˲âÊÔ×°Öã¨TIMS£©
²úÆ·Ãû³Æ£º HP4934A/JO2 ´«ÊäËðÉ˲âÊÔ×°Öã¨TIMS£©
ÐÍ ºÅ£º HP4934A/JO2
Æ· ÅÆ£º ÃÀ¹ú»ÝÆÕ Agilent
³§ÉÌ:ÃÀ¹ú»ÝÆÕ Agilent
Agilent 4934A´«ÊäËðÉ˲âÊÔ×°Öã¨TIMS£©Í¨¹ýËüµÄÒ×ÓÃÐÔ¡¢±ãЯÐԺͼá¹ÌÐÔ£¬¿ÉÒÔʹµç»°¹«Ë¾ºÍÒµÎñÌṩÉÌÌá¸ß°²×°ºÍά»¤µÄ¹¤×÷ЧÂÊ¡£²âÁ¿°üÀ¨£º
¡¤µçƽ/ƵÂÊ£¬¿É´ï110kHz(¿ÉÑ¡200kHz)
¡¤ÔëÉùºÍ¶ÔµØÔëÉù
¡¤ÒôÐźÅÔëÉùºÍÐÅÔë±È
¡¤Èý¼¶Âö³åÔëÉù
¡¤P/AR
¡¤RS-232Ô¶¶Ë¿ØÖÆ£¨²»ÊÊÓÃÓÚJ01/JO2£©
4934A TIMSÑ¡¼þJ01ÊÇ·ûºÏITU-T¼¼Êõ¹æ·¶µÄÒôƵÏß·»ò¿í´ø×¨ÓÃÏß·°²×°ºÍά»¤ÒÇÆ÷£¬Ñ¡¼þJ01ÊÊÓÃÓÚ¾ßÓÐ820Hz¹Ì¶¨ÒôƵµÄ¹ú¼Ò£¬Ñ¡¼þJ02ÊÊÓÃÓÚ¾ßÓÐ1020Hz¹Ì¶¨ÒôƵµÄ¹ú¼Ò¡£¸÷²âÁ¿¾ù·ûºÏITU-T¼¼Êõ¹æ·¶£º
¡¤µçƽ/ƵÂÊ£¬ÖÁ110KHz
¡¤µç·ÔëÉù
¡¤ÒôƵÔëÉùºÍÐÅÔë±È
Get Your Data Circuits Up and Running - and Keep Them That Way
Today, with the rapid growth in analog and digital transmissions, including DDS, ISDN and DSL, networks require more quality checks before turn up and a higher level of troubleshooting when lines develop faults. The latest version of the 4934A steps up to the challenge. With its expanded 200 kHz capability, the 4934A provides the essential level, frequency and noise TIMS measurements. The right combination of tests means a quick and accurate fault isolation. With an RS-232 port for remote control and FLASH memory for software downloads, the Agilent 4934A TIMS is a test set for today and tomorrow.
The 4934A makes commissioning new lines easy and helps diagnose troubles quickly and accurately by delivering the measurements you need in a highly portable and rugged package. It's easy to translate written test procedures into a few self-explanatory keystrokes. The reliability designed into the 4934A gives you the confidence that it will be available when it's most needed.
Features:
Cut Training Costs and Reduce Time-Wasting Errors
Simple keystroke operation
Measurement setup at a glance
Large, bright displays
Built-in operating summary
Excellent documentation
Extensive self-checking
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
