Ä£Äâʾ²¨Æ÷ TEK 7904
500MHz/1mv/0.5ns/Ë«×Ù/¶àͨµÀ
Ìå»ý£º 34¡Á30¡Á59 cm
ÖØÁ¿£º 14 kg
³§¼Ò£º ÃÀ¹úÌ©¿Ë
Ïêϸ²ÎÊý(PDFÎļþ)
Tektronix 7904 Tek 7904 500 MHz Oscilloscope Mainframe The 7904 Oscilloscope Mainframe has a 500MHz bandwidth at 10 mV/div 700 pS rise time 500 pS/div fastest calibrated sweep rate.
The TEKTRONIX 7904 Oscilloscope is a solid-state, high performance instrument designed for general purpose applications. The 7904 features a crt with small spot size and high writing rate. Graticule area is 8 X 10 cm. Additionally, the instrument includes a readout system providing crt display of alphanumeric information from the plug-ins, including deflection factor, sweep rate, and other encoded parameters.
The instrument''''s high vertical bandwidth (500 MHz), and four plug-in compartments which accept 7-series plug-in units, form a highly flexible measurement system.
ƵÆ×·ÖÎöÒDzå¼þ Spectrum Analyzer Plug-In:Tektronix 7L12
Tektronix 7L12Ïêϸ²ÎÊý(PDFÎļþ)
Tektronix 7L12 ÖÐÐÄÆµÂÊ·¶Î§£º100KHz-1.8GHz
DESCRIPTION
The 7L12 Spectrum Analyzer Plug-In provides proven, economical VHF/UHF coverage for use with 7000-Series Mainframes. Covers 100kHz to 1.8GHz with internal mixer. On-screen CRT readout of main control settings. Resolution bandwidths of 300Hz to 3MHz. Sensitivity: +30 dBm to -100 dBm at 300Hz resolution bandwidth. Frequency Span: 500Hz/div to 100MHz/div. Display modes: Log 10 dB/div, Log 2 dB/div and Linear settings. Sweep times from 10 mS/div to 1 µs/div in 1-2-5 sequence. The 7603 mainframe is recommended for the most economical system or a 7854 digitizing mainframe should be used for semiautomatic capabilities.
