Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Ê§Õæ¶È²âÁ¿ÒÇ HP339A
²úÆ·Ãû³Æ£º Ê§Õæ¶È²âÁ¿ÒÇ HP339A
ÐÍ ºÅ£º HP339A
Æ· ÅÆ£º ÃÀ¹ú»ÝÆÕ
Ê§Õæ¶È²âÁ¿ÒÇ HP339A
Distortion Measurement Set
³§ ¼Ò£ºÃÀ¹ú»ÝÆÕ
Ïêϸ²ÎÊý(PDFÎļþ)
Ultra low distortion measurements
Built-in low distortion oscillator
Automatic
True RMS detection
Ultralow distortion measuring system complete with total harmonic distortion (THD) analyzer, true rms voltmeter, and sinewave oscillator. THD measurements over the 10 Hz to 110 kHz frequency band, including harmonics to 330 kHz. Also features built-in tracking oscillator.
Distortion Measurements
fundamental frequency range is 10 Hz to 110 kHz with 2 digit resolution
measurement range is 100% to 0.01%, (0 dB to -80 dB)
Oscillator
Frequency range is 10 Hz to 100 kHz with 2 digit resolution. Output level is variable from 4 V rms to 1 mV rms.
Oscillator distortion ( >600 ohm load, <3 Vrms)
10 Hz to 20 kHz < -93 dB (0.0022%) THD
20 kHz to 30 kHz < -85 dB (0.0056%) THD
30 kHz to 50 kHz < -80 dB (0.01%) THD
50 kHz to 80 kHz < -70 dB (0.032%) THD
80 kHz to 110 kHz < -65 dB (0.056%) THD
Voltmeter
Range is 1 mV rms full scale to 300 V rms full scale.
Hewlett-Packard's Model 339A Distortion Measurement Set is an ultra low distortion measuring system complete with total harmonic distortion (THD) analyzer, true-rms voltmeter, and sinewave oscillator. This small, lightweight bench measurement set allows you to make THD distortion measurements as low as 0.0018% over a 10 Hz to 110 kHz frequency band including harmonics to 330 kHz.
For fast and easy THD measurements the built-in tracking oscillator in HP's 339A saves test time because you tune one instrument instead of two. Frequency and level measurements are easy to do with HP's 339A's voltmeter, which offers you a 1 mV to 300 V measurement range. The Relative Level mode has been included to further simplify frequency response measurements. Just set a 0 dBm reference at any frequency from 10 Hz to 110 kHz. Gain measurements can be read directly from the easy-to-read meter.
Operation Simplicity
Automatic frequency tuning and set-level features allow you to make rapid, error free THD measurements. The 339A's built-in tracking oscillator eliminates the need to find the fundamental frequency and tune the analyzer for a null. Just select your oscillator frequency and the rest is automatic. Automatic set-level saves time by automatically setting 0 dB (100%) reference in the distortion measuring mode. Front panel directional indicators light when the input range setting is improper insuring accurate and repeatable measurements where distortion as a function of a level (SINAD, for example) is desired. Without this feature, measurements are very time consuming and tedious.
When an external stimulus is used, analyzer tuning is simplified by directional indicator lights for reaching the fundamental null quickly and easily.
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
