Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ×Ô¶¯Ê§Õæ¼Æ E-2001A AUTOMATIC DISTORTION METER
²úÆ·Ãû³Æ£º ×Ô¶¯Ê§Õæ¼Æ E-2001A AUTOMATIC DISTORTION METER
ÐÍ ºÅ£º E-2001A
Æ· ÅÆ£º ÈÕ±¾NF
³§¼Ò£ºÈÕ±¾NF
³ß´ç£º212¡Á126¡Á248mm
ÖØÁ¿£º3.6Kg
Fundamental frequency range:20Hz to 20KHz in three continuous ranges with fine adjustment mechanism.
measuring range:0.1% to 100% fullscale,7 ranges
input level range:100mVr.m.s. to 100Vr.m.s.(at 100% CAL)
30mVr.m.s finely adjustable automatically
Fundamental harmonic rejection ratio:80dB and above
Higher harmonic characteristic:
secondary to quintic harmonic characteristics:
within ¡À1dB at a basic frequency of 20Hz to 10KHz
within ¡À2dB at a basic frequency of 10KHz to 20KHz
Provided,however,that the higher harmonic frequency
shall be 60KHz and below and the distortion factor 30% and below.
residual distortion factor:As shown in figure below,including hum and noise.
AC voltage measurement
Measuring range:100¦ÌVr.m.s. to 10Vr.m.s. full scale but when an input attenuator(ATT)is combinedly used.
100¦ÌVr.m.s. to 100Vr.m.s. full scale at 0dB in the input attenuator.
3mVr.m.s. to 3Vr.m.s. full scale at 30dB in the input attenuator.
100mVr.m.s. to 100Vr.m.s. full scale at 60dB in the input attenuator.
7 ranges with push-buttons used in every case mentioned above.
accuracy:within¡À3%(at 400Hz)
Frequency characteristics:
within ¡À0.5dB at 20Hz to 20KHz
within ¡À1dB at 10Hz to 200KHz
400Hz basic
Residual noise:10¦ÌVr.m.s and below(4¦ÌVr.m.s typically)in terms of input,with input short-circuited for 100¦ÌV range.
Ratings commonly applicable
input impedance:Approx.100 kilo-ohms at 70pF and below parallel capacitance
Type of input:Unbalanced binding post
output:Unbalanced binding post
"X" output:Approx.1Vr.m.s(fundamental harmonic components of input signal) in deteriming a distortion factor(at 100% calibration)
"Y" output:Approx.0.5Vr.m.s(with meter at full scale) in determining a voltage(input signal output) and a distortion factor(higher harmonic signal output)
output impedance:Aprox.2.2 kilo-ohms
meter
type of indication:mean value detected with RMS value indicated(calibrated in terms of sine-wave signal)
classification:1.5 class with mirror
scale:0 to 3 and 0 to 10(voltage in percentage scale)
-16 to +2dB (dB scale:0dB=0.775Vr.m.s)
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
