ÒôƵÐźÅÔ´ ÒôƵÐźŷ¢ÉúÆ÷
ÒôƵ·¢ÉúÆ÷ AG-203 CR Oscillator
10Hz-1MHz
³§¼Ò£ºÈÕ±¾½¨Îé KENWOOD
³ß´ç£º128¡Á238¡Á190 mm
ÖØÁ¿£º2.9Kg
¼ò½é£º
Frequency range:
¡Á1 range:10Hz-100Hz
¡Á10 range:100Hz-1KHz
¡Á100 range:1KHz-10KHz
¡Á1K range:10KHz-100KHz
¡Á10K range:100KHz-1MHz
Frequency accuracy:¡À(3%+1Hz)
[Sine wave characteristics]
output voltages(no load):7v rms or more
Frequency characteristic(reference freq:1KHz):10Hz-1MHz,¡À0.5dB
Distortion factor:
400Hz-20KHz,0.1% or less
100Hz-100KHz,0.3% or less(¡Á 10 range for 100Hz)
50Hz-200KHz,0.5% or less
20Hz-500KHz,1% or less
10Hz-1MHz,1.5% or less
[Square wave characteristics]
Output voltage(no load):10V p-p or more
sag:5% or less(at 50Hz)
Rise and fall times:200ns or less
overshoot:2% or less(at 1KHz,max.output)
duty ratio:50%¡À5%(at 1KHz,max.output)
[External synchronization characteristics]
Synchronizing range:¡À1%/v
Max.allowable input:10Vrms
Voltage:
Input impedance:Approx.10K¦¸
Output impedance:600¦¸¡À10%
Output attenuator:0dB,-10dB,-20dB,-30dB,-40dB and -50dB in 6 steps(accuracy:¡À1dB at 600¦¸ load )
[Stability anainst power source voltage variation(with respect to variation of 100V¡À10%)]
Frequency drift:Within¡À0.5%
Output voltage variation:Within¡À0.5d
