Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Êý×Ö¶àÓñí Datron 1065A/1061A
²úÆ·Ãû³Æ£º Êý×Ö¶àÓñí Datron 1065A/1061A
ÐÍ ºÅ£º 1065A/1061A
Æ· ÅÆ£º Datron
Ìå »ý£º45¡Á9¡Á42cm
Ö±Á÷¾«¶È
24 HOURS (23¡ãC+/-1¡ãC)
0.1V range: +/-20ppm of reading +/-3 digits
1V and 10V ranges: +/-15ppm of reading +/-1 digits
100 and 10 00V ranges: +/-30ppm of reading +/-1 digits
90 DAYS (23¡ãC+/-5¡ãC)
0.1V range: +/-60ppm of reading +/-4 digits
1V and 10V ranges: +/-40ppm of reading +/-1 digits
100 and 10 00V ranges: +/-70ppm of reading +/-1 digits
1 YEAR (23¡ãC+/-5¡ãC)
0.1V range: +/-80ppm of reading +/-4 digits
1V and 10V ranges: +/-60ppm of reading +/-1 digits
100 and 10 00V ranges: +/-100ppm of reading +/-1 digits
µç×辫¶È
100 ohm range: +/-25ppm of reading +/-4 digits
1k and 10k ranges: +/-15ppm of reading +/-1 digits
100k ranges: +/-20ppm of reading +/-1 digits
1000k range: +/-100ppm of reading +/-1 digits
10M range: +/-200ppm of reading +/-1 digits
100 ohm range: +/-60ppm of reading +/-4 digits
1k and 10k ranges: +/-40ppm of reading +/-1 digits
100k ranges: +/-50ppm of reading +/-1 digits
1000k range: +/-150ppm of reading +/-1 digits
10M range: +/-400ppm of reading +/-1 digits
100 ohm range: +/-80ppm of reading +/-4 digits
1k and 10k ranges: +/-60ppm of reading +/-1 digits
100k ranges: +/-70ppm of reading +/-1 digits
1000k range: +/-250ppm of reading +/-1 digits
10M range: +/-600ppm of reading +/-1 digits
½»Á÷¾«¶È
1V to 1000V ranges: +/-0.04% of reading @45Hz to 30kHz
+/-50 digits
+/-0.2% of reading @30kHz to 100kHz
+/-200 digits
+/-5% of reading @100kHz to 1MHz
+/-2000 digits
Crest Factor 5:1 typically, at full range
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
