Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ˫ͨµÀ¶¯Ì¬ÐźŷÖÎöÒÇ HP 35665A
²úÆ·Ãû³Æ£º ˫ͨµÀ¶¯Ì¬ÐźŷÖÎöÒÇ HP 35665A
ÐÍ ºÅ£º HP 35665A
Æ· ÅÆ£º ÃÀ¹ú»ÝÆÕ
³§¼Ò: ÃÀ¹ú»ÝÆÕ
Ïêϸ½éÉÜ PDF
ËùÅäÑ¡¼þ ÄÚÖÃ3.5´çÈíÇý£¬Ö§³ÖHP BASICÓïÑÔ
1D2 Swept sine measurements.
1C2 HP Instrument BASIC.
ANA Add 6 Mbytes memory.
ƵÂÊ·¶Î§£º
ͨµÀÒ» 102.4kHz
ͨµÀ¶þ 51.2kHz
·Ö±æÁ¦£º
µ¥Í¨µÀģʽ 244¦ÌHz
˫ͨµÀģʽ 122¦ÌHz
SPAN£º
µ¥Í¨µÀģʽ 102.4 kHz - 0.19531 Hz
˫ͨµÀģʽ 51.2 kHz - 0.097656 Hz
·ùÖµ¾«¶È£º¡À0.25dB
¶¯Ì¬·¶Î§£º72 dB
ͨµÀ¼äЭµ÷£º¡À0.04dB£¬0.5deg
ʱʵ´ø¿í£º12.8kHz¿ìËÙÆ½¾ù
²âÁ¿½á¹û£ºÊ±¼ä¼Ç¼¡¢ÏßÐÔÆ×¡¢¹¦ÂÊÆ×¡¢¹¦ÂÊÃܶȡ¢ÆµÂÊÏàÓ¦¡¢Ïà¹Ø¡¢×Ô¶¯/»¥Ïà¹Ø¡¢Õý̬·Ö²¼¡¢PDF£¬CDF¡£
ÏÔʾÀàÐÍ£ºµ¥Í¼¡¢Ë«Í¼¡¢Á½ÌõÇúÏßͬͼÏÔʾ¡¢×´Ì¬¼°Ë®Á÷ͼÏÔʾ¡£
¸üÐÂËÙ¶È£º8ÌõÇúÏß/Ãë
¶àÖÖ²âÊÔ·½·¨£º
¿ìËÙ¸µÁ¢Ò¶±ä»»£»°Ú¶¯ÕýÏÒ²âÊÔ£»ÉùƵ·ÖÎö£»´ÎÐò·ÖÎö£»Ïà¹Ø·ÖÎö£»ÆµÂÊÖ±·½Í¼/ʱ¼ä²âÊԵȣ¬²¢¾ßÓвâÊÔ½á¹û¼Ó¹¤¹¦ÄÜ£¬ÄÜʹ»úÆ÷¶ÔÐźŵĴ¦Àí´ïµ½Ò»¶¨µÄ¸ßµµ¼°Éî¶È£¬¼ò»¯Á˶ÔһЩÊý¾ÝµÄ´¦Àí·½Ê½¡£
Ó¦Ó÷¶Î§£º
ʱÓò¡¢ÆµÓò¼°·ùÖµÓò²âÁ¿
Õñ¶¯¼°ÔëÉù·ÖÎö
¿ØÖÆÏµÍ³²âÊÔ¼°·ÖÎö
The Agilent 35665A is a 2-channel Dynamic Signal Analyzer providing measurement solutions in vibration, acoustics, and control systems. Its major options are computed order tracking, real-time octave, swept sine, curve fit and synthesis, arbitrary source, and Instrument BASIC.
Features
1-channel at 102.4 kHz, 2 channels at 51.2 kHz.
100, 200, 400, 800 lines of resolution.
Tachometer input.
Built in 3.5" floppy disk.
Source: Random, burst random, pink noise, sine, swept-sine, arbitrary, periodic chirp, burst chirp.
3.2 M Sample time-capture buffer (optional).
Measurements: linear spectrum, cross-spectrum, power spectral density, frequency response, time waveform, auto-correlation, cross-correlation, histogram, PDF, CDF.
Optional real-time octave, computed order tracking, swept-sine, curve fit, synthesis, and arbitrary source.
µç»° 010 - 62123258 / 59 buy17@126.com
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
