HP 3325BÊÇһ̨¾ß±¸ÆµÂÊ׼ȷ¶È¡¢·Ö±æÂʺÍÎȶ¨¶ÈµÄ²úÉúÆ÷/²¨ÐÎºÏ³ÉÆ÷£¬ÊʺϾ§ÌåÂ˲¨Æ÷²âÊÔ¡¢¶àÈÎÎñͨѶϵͳ²âÊÔ¡¢Ê±Âö/ʱÐòµÄ·ÂÕæ¼°ÓïÒôƵÂÊϵͳ²âÊÔµÈÓ¦Óá£
Õë¶ÔVCO²âÊÔ»òÖÆ³Ì¿ØÖƵÈÓ¦Ó㬲úÉú¾ßºÏ³É׼ȷ¶ÈºÍÎȶ¨¶ÈµÄÓÅÒìÏßÐÔÈý½Ç²¨ºÍб²¨£¨ramp£©Ðźš£Ö±Á÷µ½21 MHzµÄƵÂÊ·¶Î§£¨ÕýÏÒ£©£¬Ê¹3325B·Ç³£ÊʺÏÓÃÀ´Ö´ÐиßЧÄÜÓ°ÏñϵͳµÄ²âÊÔ¡£
´¿ÕýÏÒ²¨»ò¸ßÆ·ÖÊ·½²¨¿ÉÒԺ͸ߴï¡À5VµÄÖ±Á÷Æ«ÒÆºÏ²¢£¬ÒÔÁ¬½Óƫѹµç·»ò×÷ΪÐźŻ·¾³Öе路¢¡£ÔÚµ÷±äÓ¦Ó÷½Ã棬¿ÉÈÃHP 3325BÌá¹©ÔØ²¨ÒÔ×÷Ϊµ÷±äÐźÅÔ´£¬»òʹÓÃÄÚ²¿µ÷±äÐźÅÔ´£¬Ö»´Ó3325BÈ¡µÃµ÷±äÐźš£
¡¤ º¯Êý£ºÕýÏÒ¡¢·½²¨¡¢Èý½Ç²¨¡¢¸ººÍÕýб²¨¡¢ÈÎÒⲨÐΡ¢Ö±Á÷Æ«ÒÆ
¡¤ ÍêÈ«ºÏ³ÉµÄmHz·Ö±æÂÊ
¡¤ ÄÚ½¨¿É³Ì¿Øµ÷±äÐźÅÔ´
¡¤ LOG¡¢LIN¡¢·ÇÁ¬ÐøÉ¨Ãè
¡¤ ÓÅÒìµÄÐźŴ¿¶È
¡¤ Ö±Á÷µ½60 MHzµÄͬ²½Êä³ö
¡¤ ²Ù×÷ζȣº0µ½55¡æ
¡¤ Ïà¶Ôʪ¶È£º95%£¬0µ½40¡æ
¡¤ ¸ß¶È£º15,000Ó¢…ÕÒÔÏÂ
¡¤ ¹¦ÂÊ£ºËùÓÐÑ¡Ïî¶¼Ìṩ100/120/220/240 V£¬+ 5%£¬-10%£¬48µ½66 Hz£¬90 VA£¬120 VA
¡¤ ÖØÁ¿£º¾»ÖØ9¹«½ï£¬×ÜÖØ14.5¹«½ï
¡¤ ³ß´ç£¨¸ßx¿íxÉ£º133.4 mm x 425.5 mm x 498.5 mm
²¨ÐÎ: ÕýÏÒ²¨, ·½²¨, Èý½Ç²¨, Õý¸ºÐ±²¨
ƵÂÊ ·¶Î§
ÕýÏÒ²¨: 1µHz - 20.999 999 999 MHz
·½²¨: 1µHz - 10.999 999 999 MHz
Èý½Ç²¨: 1µHz - 10.999 999 999 kHz
·Ö±æÂÊ: 1µHz < 100 kHz; 1 mHz > 100 kHz
Main Signal Output (ËùÓв¨ÐÎ)
×迹: 50 ohm
½Ó¿Ú: BNC; ǰºóÃæ°å¿ª¹ØÇл»
·ù¶È
·¶Î§: 1 mV to 10V p-p in 8 amplitude ranges, 1-3-10 sequences (10 dB steps), 50 ohm ¸ºÔØ
µ¥Î»ÏÔʾ
Peak-peak rms dBm (50 ohm)
ÕýÏÒ²¨ÆµÆ×´¿¶È
ÏàλÔëÉù: -60 dB for a 30 kHz band centered on a 20 MHz carrier with high-stability Option 001 installed.
Spurious: All non-harmonically related output signals will be more than 70 dB below the carrier (60 dB with dc offset) or less than -90 dBm, whichever is greater.
ÕýÏÒ²¨Ð³²¨Ê§Õæ¶È:
Harmonically related signals will be less than the following levels (relative to the fundamental) at full output for each range:
0.1Hz 50kHz 200kHz 2MHz 15MHz 20MHz
-65 dB -60 dB -40 dB -30 dB -25 dB
·½²¨ÌØÐÔ - ÉÏÉý Ͻµ ʱ¼ä: < 20 ns, 10% to 90% at full output
Offset
·¶Î§: ½öÖ±Á÷ (ÎÞ½»Á÷): 0 to ¡À5.0V/50 ohm
DC + AC: Maximum dc offset ¡À4.5V on highest range, decreasing to ¡À4.5mV on lowest range
ÕýÏÒ²¨µ÷·ù
Modulation Depth at Full Output for Each Range: 0 to 100%
µ÷ÖÆÆµÂÊ·¶Î§: DC to 400kHz (ÔØ²¨ 0 - 21 Mhz)
ÕýÏÒ²¨µ÷ÖÆ
Range: ¡À850¡ã, ¡À5 V input
Modulation Frequency Range: DC to 5kHz
ɨƵ
ɨÃèʱ¼ä
ÏßÐÎ: 0.01s - 1000s
¶ÔÊý: 1s - 1000s µ¥´Ê, 0.1s - 1000s Á¬Ðø
ÀëɢɨÃè
Number of Segments: 100 maximum
Time/Segment: 0.01s to 1000s, 0.01s resolution
×î´óɨÃè¿í¶È: Full-frequency range for the wave form in use; minimum log start frequency 1 Hz
Ïàλ: Á¬Ðø¸²¸ÇËùÓÐÆµÂÊ·¶Î§
µ÷ÖÆÔ´
ƵÂÊ·¶Î§: ÕýÏÒ 0.1Hz - 10kHz, ·½²¨ 0.1Hz - 2kHz
²¨ÐÎ: ÕýÏÒ, ·½²¨, ÈÎÒâ
AUXILIARY INPUTS AND OUTPUTS
Auxiliary Frequency Output: 21MHz to 60.999 999 999MHz; 0 dBm; output impedance 50 ohm
Sync Output
X-Axis Drive
Option 001 ¸ßÎȶ¨ÐÔÆµÂʲο¼
Option 002 ¸ßѹÊä³ö
ƵÂÊ·¶Î§: 1µHz - 1MHz
·ù¶È·¶Î§: 4.00mV p-p to 40.00V p-p (into >500 ohms, <500 pF load)
