Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Êý×ִ洢ʾ²¨Æ÷ HP 54602A
²úÆ·Ãû³Æ£º Êý×ִ洢ʾ²¨Æ÷ HP 54602A
ÐÍ ºÅ£º HP54602A
Æ· ÅÆ£º ÃÀ¹ú»ÝÆÕ
Êý×ִ洢ʾ²¨Æ÷ HP 54602A¡¡
³§¼Ò: ÃÀ¹ú»ÝÆÕ
( 322x172x317mm£¬6.2kg)
Bandwidth 150 MHz
Number of Channels 4 ch
Simultaneous Channels 2 ch
Simultaneous Maximum Sampling Rate/ch 20 MSa/s
One ch. only max. sampling rate 20 MSa/s
Max. Single Shot bandwidth 2 MHz
Max. Record Length 4000 pt/sec
Min. Vertical Sensitivity 2 mV/div
Maximum Vertical Sensitivity 5 V/div
Rise time 2.33 ns
Number of Bits 8 bits
Input Impedance 1 MOhm
Input Coupling AC,DC,GND
Maximum Input Voltage 400 Vrms
Main time base - lowest 2 ns/div
Main time base - highest 5 s/div
Timebase accuracy 0.01 %
Trigger Source Internal
Trigger Modes Auto,Single,Trigger,TV
Minimum Trigger Holdoff 200 ns
Trigger Sensitivity 3.2 mV
Minimum Glitch Trigger 1 ns
Display Type CRT Monochrome
Display Size 17.78 cm
¶þÊÖÒDZí;010-62123258 / buy17@126.com
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
