ÎÞÏßµç×Û²âÒÇ HP8922M+83220E
GSM Mobile Station Test Set
³§¼Ò: ÃÀ¹ú»ÝÆÕ
³ß´ç: 44x31x61cm
ÖØÁ¿: 48 kg
ÐÔÄÜÖ¸±êpdf
ƵÂÊ·Ö±æÂÊ£º1Hz£¨ÌøÔ¾Ä£Ê½ÖÐΪ100MHz£© ת»»ËÙ¶È£º557¦Ìs
Ïà¹ØÊý¾Ý½âµ÷£º0.3GMSKÔÚ270.833kb/sÉÏ£¬1ʱ϶/Ö¡ Ä£Äâ½âµ÷£ºµ÷ƵºÍÂö³å
×ۺϷ½·¨£º rmsºÍ·åÖµÏàλÎó²î¡¢ÆµÂÊÎó²î ·ù¶È°üÂ磺ÉÏÉý¡¢Ï½µºÍÓÐÓñÈÌØÉϵÄÍ»·¢Æ½Õû¶ÈË𻵠·¢Éä»ú·åÖµ¹¦ÂÊ:+10dBm¡«+45dBm,(-5dBm¡«41dBm,Agilent 8922F/H)
Êä³öÉäÆµÆµÆ×²âÁ¿1£ºÈ¡¾öÓÚµ÷ÖÆºÍÕù»»µÄ˲±ä¹ý³Ì
- RF Generator
Frequency Range: 10 MHz to 1000 MHz
Frequency Resolution: 1 Hz
Switching Speed: 577us
0.3 GMSK Modulation: External clock and data
Pulse Modulation: Normal and 30dB
Output Power: -14 to -127 dBm
- Spectrum Analyzer (Option 006)
Frequency Accuracy and Stability: Same as timebase
Display Range: 80 dB
Other Features: External trigger, marker
Digital Oscilloscope
Frequency Range: 2 Hz to 50 kHz
Sweep Times: 10us to 100 ms in 1,2,5,10 steps
Audio Analyzer
Frequency Range: 20 Hz to 400 kHz
AC Voltage Range: 0 to 30 Vrms
DC Voltage Range: 100 mV to 42 V
THD + Noise: 1 kHz ¡À 5 Hz
SINAD: 1 kHz ¡À 5 Hz
Audio Source
Frequency Range: DC to 25 kHz
Output Level Range: 0.1 mVrms to 4 Vrms
