¸ßËÙ²ÉÑùʾ²¨Æ÷ Agilent/HP 54750A
³§¼Ò: ÃÀ¹ú°²½ÝÂ×/»ÝÆÕ ( cm£¬24.5kg)
The Agilent 54750A is a modular system. Up to four high-bandwidth channels and TDR are supported by the mainframe. The modular design allows for expansion to meet changing needs.
The 20-GHz or 50-GHz bandwidth and the low-noise specifications allow very precise measurements on low-level, high-speed signals. Timebase stability, accuracy, and resolution allow characterization of jitter in the most demanding applications.
- 62.5-fs Resolution
- 10-ps Accuracy
- TDR/TDT²âÁ¿
- ´æ´¢Éî¶È£º4k/CH
- Êý¾Ý´«ÊäÂÊ£º550Kbytes/s typical
Å䣺Agilent 54753A Single Ended TDR/TDT Plug-In Module
The Agilent 54753A TDR/TDT plug-in modules provide you with TDR and TDT measurement features. In addition to the TDR and TDT measurement features, the TDR plug-ins provide two accurate oscilloscope measurement channels with user selectable bandwidths of 12.4 or 18 GHz. The lower bandwidth mode provides excellent oscilloscope noise performance for accurate measurement of small signals. The high bandwidth mode provides high-fidelity display and measurement of very high-speed waveforms.
- ͨµÀÊý£º2 CH
- Óû§¿ÉÑ¡Ôñ´ø¿í£º12.4 or 18 GHz (Channel 1)
- Óû§¿ÉÑ¡Ôñ´ø¿í£º12.4 or 20 GHz (Channel 2)
- 2.5 GHz ´¥·¢Í¨µÀ
- ´ø¿í£ºTDR/´¹Ö±Í¨µÀÉÏΪ20-GHz¡¢18-GHz
- ´¹Ö±¾«¶È£º0.4%
- ´¹Ö±·Ö±æÂÊ£º12λ£¨Æ½¾ùֵΪ15£©
- ×î´óÔëÉù£º< 1 mVrms
- Automatic and manual single-ended TDR and TDT measurement capability
- Automatic and manual waveform, histogram, FFT, waveform math, eye pattern measurements, statistical measurements, and limit testing capabilities
µç»°: 010 - 62123258 / 62123259 ÓÊÏä: buy17@163.com
