²úÆ·Ãû³Æ£º
µ÷Ƶµ÷·ùÐźŷ¢ÉúÆ÷ Marconi 2022D
ÐÍ ºÅ£º
Marconi 2022D
³§¼Ò: Ó¢¹úÂí¿ÉÄá
- ƵÂÊ·¶Î§: 10 kHz to 1 GHz(7λҺ¾§ ÏÔʾ¾«¶È10 Hz up to 100 MHz, 100 Hz above 100 MHz)
- Êä³ö·ù¶È: -127 dBm to +13 dBm
- µ÷ÖÆ£ºµ÷Ƶ¡¢µ÷·ù¡¢µ÷Ïà;Íâ½Óµ÷ÖÆ;ÈýÖÖÄÚ²¿µ÷ÖÆÆµÂÊ
Aux modulation input
- ³ß´çСÇÉ£¬·½±ãЯ´ø 152 x367 mm , 7.5 kg
- 100×é¼ÇÒäÉ趨
- Ç¿´óµÄµÚ¶þ¹¦ÄܼüÓÃÓÚ¿ìËÙ¹ÊÕ϶¨Î»ºÍУ׼
- Reverse power protection up to 50 W
- Choice of output cal. units
Output level can be offset Parameters can be incremented
| Êä³öµçƽ |
-127 to +13 dBm (0.2 uV to 2 V EMF). When AM is selected the max. output power reduces linearly with AM depth to +7 dBm at maximum AM depth. |
| µ¥Î» |
µ¥Î»¿ÉÒÔÊÇuV, mV, V EMF or PD; dBÏ൱ÓÚ1uV, 1 mV EMF or PD; dBm. |
| ÏÔʾ |
4 λ LCD |
| ÏÔʾ¾«¶È |
0 .1 dB |
| Êä³öµçƽ¾«¶È |
+1 dB £¨-10 dBm ÒÔÉÏ£© +2 dB £¨-10 dBm ÒÔÏ£© |
| Êä³öµçƽƽ̹¶È |
Better than +0.5 dB from 10 kHz to 1 GHz for output levels above -7 dBm. |
| Êä³ö×迹 |
50Å· NÐÍÍ· VSWR is better than 1.5:1 for output levels below -7 dBm. |
| ×î´óµ¥±ß´øÔëÉù |
-120 dBc/Hz |
| Harmonics (noise) |
-35 dBc |
| Non-harmonics (noise) |
-40 dBc |
| Íâ½ÓƵÂʲο¼ |
10 MHz |
