| Synthesizer |
| Spectralpurity |
| PHASENOISE(25-kHz offset) |
| f<500MHz |
<-121dBc/Hz |
| f¨R500MHz |
<-115dBc/Hz |
| RESIDUALFM |
| f<500MHz |
4Hz(rms,CCITT-weighted) |
| f¨R500MHz |
8Hz(rms,CCITT-weighted) |
| NONHARMONICSPURIOUS SIGNALS>500Hz off carrier |
<-55dBc |
| HARMONICS |
| Level<-15.1dBm |
<-25dBc |
| Level¨R-15.1dBm |
<-20dBc |
| RESIDUALAM |
<0.02%(rms,CCITT-weighted) |
| 10-MHzreference oscillator |
| WARMUP TIME |
<3min for frequency error <5*10-7 <10minfor frequency error10-7 |
| FREQUENCYERROR |
<1*10-7(T=5 to 45¡æ) |
| AGING |
<5/month |
| OUTPUTLEVEL |
approx.0.4V(into 50¦¸) |
| SYNCHRONIZATION |
10MHz,V>150mVrms(into200¦¸) |
| RF Generator |
| Carrierfrequency |
| FREQUENCY RANGE |
0.4to 999.9999MHz |
| RESOLUTION |
| f<500MHz |
50Hz |
| f¨R500MHz |
100Hz |
| FREQUENCYERROR |
as reference oscillator |
| Outputlevel |
| RF SOCKET |
-142to -7dBm(max.-13dBm with AM) |
| RFDIRECT SOCKET |
-122 to +13dBm(max.+7dB with AM) |
| resolution |
0.1dB |
| LEVELERROR INTO 50¦¸ |
| RFsocket |
| Level¨R-130dBm |
<1.3dB |
| Level>-15.0dBm |
<2dB |
| RFDIRECT socket |
| Level¨R-110dBm |
<1.6dB |
| Level>+5.0dBm |
<2.5dB |
| VSWR(50¦¸)RFSOCKET |
<1.1 |
| EMFsetting range with out interruption(not with AM) |
0 to 15dBusable to 20dB |
| Additional level error |
0.1dBper dB |
| Modulation |
| FM(AC-coupled) |
| FREQUENCYDEVIATION |
0 to 40kHz |
| MODULATIONFREQUENCY(int.and ext.) |
30Hz to 30kHz |
| RESOLUTION |
10Hz |
| SETTINGERROR |
| fmod=300Hzto 3kHz |
<5%+3digits |
| fmod=30Hzto 20kHz |
<10%+3digits |
| DISTORTION(dev.<10kHz) |
| fmod=300Hzto 3kHz |
<1% |
| EXT.MOD.INPUT |
20kHzFM=0.707 Vrms into 600¦¸ |
| FM(external DC-coupled) |
0 to 5kHz |
| MODULATIONFREQUENCY |
0 to 30kHz |
| CENTRE-FREQUENCYERROR |
<100Hz +frequency error of reference oscillator |
| §æM |
| PHASEDEVIATION |
0 to 6rad(fmod*rad¨R20kHz) |
| RESOLUTION |
0.01rad |
200Hz to 6kHz |
| SETTINGERROR |
| fmod=300Hzto 3kHz |
<1% |
| EXT.MOD.INPUT |
20RAD §æM=0.707Vrms into 600¦¸ |
| AM |
| MODULATIONDEPTH |
m=0 to 99.9% |
| RESOLUTION |
0.1% |
30Hz to 10kHz |
| SETTINGERROR FOR M¨R90% |
| fmod=30Hzto 10kHz |
<0.1*m+1digit |
| DISTORTIONfor m<50% |
| fmod=300Hzto 3kHz |
<2% |
| EXT.MOD.INPUT |
50%AM=0.707Vrms into 600¦¸ |
| RF Analyzer |
| Frequencymeasurement |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| RESOLUTION |
10Hz |
| ADMISSIBLEINPUT LEVEL |
| onRF socket |
0.1 mW to 125W |
| MEASURINGACCURACY |
as reference oscillator¡À10Hz |
| Frequency-offsetmeasurement |
| FREQUENCY RANGE |
2to 999.9999MHz |
| MEASURINGRANGE |
0 to ¡À99.99kHz |
| RESOLUTION |
| f<10kHz |
1Hz |
| f<¨R10kHz |
10Hz |
| on RFsocket |
2¦ÌW to 125W |
| onRF DIRECT socket |
1mV to 1V(measuring range:0 to¡À15kHz) |
| MEASURING ACCURACY |
as referenceoscillatior+3Hz(+1digit for offset¨R10kHz) |
| RF-powermeasurement,RF-socket(broadband) |
| FREQUENCY RANGE |
2to 999.99MHz |
| MEASURINGRANGE |
1mW to 125W(average) |
| RESOLUTION |
| P<1W |
1mW |
| P<10W |
10mW |
| P<¨R10W |
100mW |
| MEASURINGACCURACY(w/o modulation) |
| P>200mW |
<10%+1digit (f=20to 500MHz) <12%+1digit (f=6 to 999.9999MHz) |
| RF-powermeasurement(bandwidth approx.3MHz) |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| MEASURINGRANGE |
| RFsocket |
-45 to +37dBm |
| RFDIRECT socket |
-65 to +17dBm |
| MEASURINGACCURACY |
3dB |
| RESOLUTION |
0.1dBm |
| Modulationmeasurement |
| FMmeasurement,RF socket(broadband) |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| INPUTLEVEL |
0.1mW to 125W |
| MEASURINGRANGE |
0 to 25kHz |
| RESOLUTION |
10Hz |
| MEASURINGACCURACY(dev.<<10kHz) |
| fmod=300Hzto 3kHz |
5%¡À1digit¡Àpeak residual FM |
| fmod=100Hzto 10kHz |
10%¡À1digit¡Àpeak residual FM |
| DEMODULATIONDISTORTION |
| fmod=300Hzto 3kHz |
<0.5% |
| PEAKRESIDUAL FM |
<50Hz or <10Hz/100MHz |
| FMmeasurement,RF DIRECT socket(narrowband) |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| INPUTLEVEL |
-50 to -20dBm |
| MEASURINGRANGE |
0 to 10kHz(fmod*dev.<10kHz) |
fmod=0 to 6kHz |
| RESOLUTION |
10Hz |
| SENSITIVITY |
betterthan 2mV(3kHz FM dev.,10dB SINAD,CCITT-weigthed) |
| IFBANDWIDTH |
30kHz |
| §æMmeasurement,RF socket(broadband) |
| FREQUENCY RANGE |
2to 999.9999MHz |
| INPUT LEVEL |
0.1mWto 125W |
| MEASURING RANGE |
0 to6rad(FM dev.<50kHz) |
| RESOLUTION |
0.01rad |
| MEASURINGACCURACY |
| fmod=300Hzto 3kHz |
6%¡À2digits |
| fmod=200Hzto 10kHz |
10%¡À2digits |
| fmod=300Hzto 3kHz |
<0.5% |
| §æMmeasurement,RF DIRECT socket(narrowband) |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| INPUTLEVEL |
-50 to -20dBm |
| MEASURINGRANGE |
0 to 3 rad(fmod*§æM dev.<15kH) |
200Hz to 6kHz |
| SENSITIVITY |
betterthan 2mV(3rad §æMdev,10dB SINAD CCITT-weighted) |
| IFBANDWIDTH |
30kHz |
| AMmeasurement |
| FREQUENCYRANGE |
2 to 999.9999MHz |
| MEASURINGRANGE |
0 to 100% |
| INPUTLEVEL |
| RF socket |
1mWto 125W |
| RF DIRECT socket |
0.01mWto 0.5W |
| RESOLUTION |
0.1% |
| MEASURINGACCURACY(m<¨R10% |
| fmod=Hzto 10kHz |
10%¡À2digits |
| fmod=300Hzto 3kHz |
<1% |
DC to 10kHz |
| Spurious-modulationmeasurement |
| INPUTLEVEL |
| RF socket |
1mW to 125W |
| RFDIRECT socket |
20mW to 1V |
| MEASURINGRANGE |
0 to -40dB(CCITT-weighted)referred to 3kHz FM dev.)3rad§æMdev.or 30%AM |
| MEASURINGACCURACY |
1dB |
| AFGenerator |
| Modulationgenerator GEN A |
| FREQUENCY RANGE |
30Hzto 30kHz |
| RESOLUTION |
| f<3kHz |
0.1Hz |
| f¨R3kHz |
1Hz |
| FREQUENCYERROR |
<0.01% |
| LEVELRANGE(EMF) |
0.1mVrms to 5Vrms |
| RESOLUTION |
| EMF¨Q5V |
10mV |
| EMF¨Q1V |
1mV |
| EMF¨Q0.1V |
0.1mV |
| EMF¨Q10mV |
10¦ÌV |
| LEVELERROR |
| f=100Hz to3kHz |
<3% |
| f=50Hzto 15kHz |
<10% |
| DISTORTION |
| f=30Hzto 3kHz |
<0.5% |
| f>3kHz |
<1% |
| OUTPUTIMPEDANCE(balanced) |
| f=300Hzto 3kHz |
<10¦¸ |
| f=30Hzto 30kHz |
<40¦¸ |
| OUTPUT IMPEDADNCE(unbalanced) |
600¦¸¡À5% |
| PERMISSIBLELOAD IMPEDANCE |
>200¦¸ |
| AFAnalyzer |
| AFvoltmeter |
| FREQUENCYRANGE |
30Hz to 30kHz or to CCITT P53A |
| MEASURINGRANGE |
0.1mV to 20V |
| RESOLUTION |
| Level<0.1V |
0.1mV |
| Level<1V |
1mV |
| Level<10V |
10mV |
| Level<20V |
100mV |
| MEASURINGACCURACY |
| f=300Hzto 3kHz |
3% |
| f=50Hzto 15kHz |
6% |
| SOURCEIMPEDANCE |
>100k¦¸ or 600¦¸¡À3% |
| INPUTCAPACITANCE |
20pF |
| AFcounter |
| Frequencyrange |
30Hz to 30kHz |
| INPUTLEVEL |
5mV to 20V |
| RESOLUTION |
| f<300Hz |
0.1Hz |
| f<10kHz |
1Hz |
| f¨R10kHz |
10Hz |
| MEASURINGACCURACY |
0.01%¡À1digit |
| Distortionmeter |
| INPUTLEVEL |
0.1 to 20V |
| TEST FREQUENCY |
1kHz¡À5Hz |
| MEASURINGRANGE |
0 to 99% |
| RESOLUTION |
0.1% |
| MEASURINGACCURACY |
| d=1 to90% |
5% of emas.value¡À3 digits |
| SINADmeter |
| INPUT LEVEL |
0.1 to 20V |
| MEASURINGRANGE |
1 to 46dB |
| RESOLUTION |
| SINAD<30dB |
0.1dB |
| SINAD<¨R30dB |
0.5dB |
| MEASURINGACCURACY for SINAD <30dB |
0.8dB¡À1digit |
| Scope& Analyzer |
| Spectrumanalyzer |
| FREQUENCYRANGE |
| FREQUENCYACCURACY better than 2% of sweep with INPUT-LEVEL RANGE for measuring accuracy3dB in the frequency range 0.5*fc¨Qf¨Q2*fc |
| RF socket |
-70to +47dBm |
| RF DIRECTsocket |
-90 to +13dBm |
| SWEETWIDTH |
200kHz,2MHz,10MHz |
| SWEEPTIME |
| Wweep width2MHz and 10MHz |
approx.500ms |
| Sweepwidth 200kHz |
approx.2s |
| EVEALUATIONBANDWIDTH |
| Sweepwidth 2MHz and 10MHz |
30kHz |
| Wweepwidth 200kHz |
6kHz |
| INHERNTNOISE on RF DIRECT socket |
| Sweep width 2MHz and 10MHz |
-95dBm |
| Sweepwidth 200kHz |
-105dBm |
| Oscilloscope |
| INPUTSEXTERNAL |
Zi=1M¦¸/40pF(AC/DC) |
| INPUTSINTERNAL |
RX mod,TX demod,duplex demod,AF voltmeter,residualdistortion |
| FREQUENCYRANGE |
DC(3Hz) to 20kHz |
| LEVELERROR |
<10% +0.2div |
| GRATING |
6*10div |
| HORIZORTALDERLECTION |
2¦Ìs/div to 500ms/div |
| VERTICALDEFLECTION |
2mV/div to 10V/div or 160Hz/divto 8kHz/div(FM) 0.16rad/div to 8rad/div (§æM) 0.8%/div to 40%/div(AM) |
| TRIGGER |
¡Àslopeselectable trigger leve |
| OPERATINGMODES |
auto,norm,one-shot,freeze,tyne measurement(max.reslution2.5¦Ì) |
| Selective-call encoder and decoder |
| Standardtone sequences |
XVEI 1,CCIR,VDEW,ZVEI 2,EEA,NATEL,EIA,EURO,CCITT |
| User-definedtone sequences |
| Sequenceof up to 30 tones can be stored by user.Also double tones and underlying continuoustone (with GEN B option) |
| Encoder |
| Operatingmodes |
SINGLE-TONESEQUENCE(max.30 tones) DOUBLE-TONE SEQUENCE(with GEN B option) (single-toneand double-tone sequences can be transmitted continuously) ACKNOWLEDGEMENTCALL(max.30 tones) from response time of <100ms acknowledgement call onlypossible with optional duplex FM/§æM stage FREQUENCY ERROR |
| Decoder |
Decodingof each tone of tone sequencse (max.30tones) Continuous decoding can be set |
| General |
| Dimensionsand weight |
| H*W*D |
230mm*375mm*486mm |
| WEIGHT |
approx.18.5kg |
| Powersupply AC |
94 to 132Vor 187 to 264V(47 to 450Hz) |
| Pmax |
approx.110W(incl.options) |
| Environment |
| OPERATING TEMPERATURE |
5to 45¡æ |
| STORAGE TEMPERATURE |
-40 to +70¡æ |
| RELATIVEHUMIDITY |
max.90% |
| Mechanicalstrength (to DIN 40046) |
| SHOCK |
25g |
| VIBRATION |
5to 10Hz for 10mm amplitued 10 to 60Hz,2g constant |
| EMCconformity |
EN 55022:19995,class B EN 60801:1994,part 2test level 1 ENV 50140:1995,test level 2 IEC1000-4-4:1995,test level 3 |
| Safety |
EN61010:1995,part 1 |
| IEEE-bus interface |
| STANDARD |
IEEE-488 |
| CONNECTOR |
24-way |
| FUNCTIONS |
AH1,SH1,L2,T1,SR1,RL1,DC1 |
| Frequencyextension |
| Thefollowing specifications apply to the FEX option |
| RFGenerator |
| Carrierfrequency |
| FREQUENCYRANGE |
1.0 to 2.3GHz |
| RESOLUTION |
1kHz |
| Outputlevel |
| RFsocket |
-142 to -20dBm |
| RFDIRECT SOCKET |
-122 to 0 dBm |
| LEVELERROR into 50¦¸(1.0 to 2.0GHz) |
| RF socket |
1.5dB(overrange-110 to -20dBm) |
| VSWR(50)RFsocket |
<1.2 |
