Êý×Öʾ²¨Æ÷ DL4200 / DL4100
ÈÕ±¾ºáºÓ 300x220x427mm 15kg
DL4200 ´ø¿í300MHz (DL4100 ´ø¿í150MHz)
È«ËÄͨµÀ ²ÉÑùÂÊ100MSa/s ¼Ç¼³¤¶È100k ͨѶ½Ó¿ÚIEEE-488 ±¾»ú×Ô´øÈÈÃô´òÓ¡»ú
The Yokogawa DL4200 oscilloscope is a graph-displaying device ¨C it draws a graph of an electrical signal. In most applications, the graph shows how signals change over time: the vertical (Y) axis represents voltage and the horizontal (X) axis represents time. The intensity or brightness of the display is sometimes called the Z axis.
The Yokogawa DL4200 oscilloscope's simple graph can tell you many things about a signal, such as: the time and voltage values of a signal, the frequency of an oscillating signal, the ¡°moving parts¡± of a circuit represented by the signal, the frequency with which a particular portion of the signal is occurring relative to, other portions, whether or not a malfunctioning component is distorting the signal, how much of a signal is direct current (DC) or alternating current (AC) and how much of the signal is noise and whether the noise is changing with time.
- Ö÷ÏÔʾºÍËõ·ÅºóµÄͬʱÏÔʾ( MAIL & ZOOM )
- 100ms/divÒÔÉϺ¬100m¹ö¶¯ÏÔʾ ( ROLL )
- È¡Ñù100MSa/sʱ×î¿ì500ns/div£¬¸ü¿ìÊ±ÎªÖØ¸´·½Ê½
- Auto self cal
- A+B, A-B, AxB
- displays 8 traces
- Zoom function
- Digital filtering
- GO/NOGO
- 27 waveform meas.
- Power spectrum
- Display Update Rate: 60 pt/sec
| Bandwidth ´ø¿í |
300 MHz (DL4100: 150MHz) |
| Number of Channels ͨµÀÊýÁ¿ |
4 ch |
| Simultaneous Channels |
4 ch |
| Simultaneous Maximum Sampling Rate/ch |
100 MSa/s |
| One ch. only max. sampling rate |
100 MSa/s |
| Max. Single Shot bandwidth |
40 MHz |
| Max. Record Length |
100k pt/sec |
| Min. Vertical Sensitivity |
2 mV/div |
| Maximum Vertical Sensitivity |
5 V/div |
| Rise time |
1.167 ns (DL4100: 2.33 ns) |
| Number of Bits |
10 bits |
| Input Impedance |
1 MOhm |
| Input Impedance (alternate) |
50 Ohm (DL4100ÎÞ) |
| Input Coupling |
AC,DC,GND |
| Maximum Input Voltage |
250 Vrms |
| Maximum Input#2 (for Impedance #2) |
5 Vrms |
| Main time base - lowest |
2 ns/div |
| Main time base - highest |
50 s/div |
| Timebase accuracy ʱ»ù¾«¶È |
0.005 % |
| Trigger Source ´¥·¢Ô´ |
External,Internal |
| Trigger Modes ´¥·¢Ä£Ê½ |
Auto,Edge,Gate,Normal,Single,TV ( NTSC,PAL,HDTV ) |
| Trigger Sensitivity ´¥·¢ÁéÃô¶È |
1 mV |
| Display Type ÏÔʾÆÁÀàÐÍ |
CRT |
| Display Size ÏÔʾÆÁ³ß´ç |
25.4 cm |
| Display modes ÏÔʾģʽ |
Split,Zoom |
| External Video Out |
Yes |
µç»°: 010 - 62123258 / 62123259 ÓÊÏä: buy17@163.com
