²å¼þ HP 83485A ( 12.4GHz 20GHz )
Each channel has two selectable bandwidth settings. In the lower bandwidth mode: of 12.4 GHz, oscilloscope noise performance is excellent, while the 20 GHz mode provides greater fidelity for high-speed signals. The optical channel: is calibrated at 1310nm and 1550nm. It also has a switchable filter to produce a calibrated SDH/SONET reference receiver.
Options:
- 012 FC/PC Connector
- 017 SC Connector
- 032 SDH/SONET STM-4/OC-12 622MB/s Filter
- 034 SDH/SONET STM-16/OC-48 2.4 GB/s Filter
- RMKT Agilent Refurbished Product
- UK6 Commercial Calibration Certificate w/Test Data
- H92 2488 & 9953 Mb/s
