²úÆ·Ãû³Æ£º
¸ßƵÐźÅÔ´ SME03E
ÐÍ ºÅ£º
SME03E
¸ßƵÐźÅÔ´ SME03E
³§¼Ò: µÂ¹ú Rohde & Schwarz
SME02: 5kHz - 1.5GHz SME03: 5kHz - 3GHz SME03E: 5kHz - 2.2GHz ÏÖ»õ SME06: 5kHz - 6GHz
ÒÇÆ÷¼ò½é
- ÓÃÓÚÊý×ÖͨÐŲâÁ¿£¬Ö§³Ö¸÷ÖÖÒÆ¶¯Í¨Ðŵ÷ÖÆ·½Ê½£¬ SMEÐźŷ¢ÉúÆ÷Ìṩ¿ª·¢ºÍ²âÊÔÊý×ÖÒÆ¶¯Í¨ÐŽÓÊÕ»úËùÐèµÄ¸´ÔÓÐźš£
- ÒÆ¶¯Í¨Ðűê×¼¶ÔÓÚÐźŵ÷ÖÆÀàÐÍÊý¾Ý¸ñʽTDMA½á¹¹ÒÔ¼°ÌøÆµ·½°¸¾ù×ö³ö¹æ¶¨¡£SMEÄܹ»²úÉú·ûºÏËùÓÐÕâЩ¹æ¶¨²¢ÄÜÊÊÓÃÓÚ¸÷ÖÖÖ÷Á÷Êý×ÖÒÆ¶¯Í¨ÐÅÍøÂçµÄ²âÊÔÐźš£
- ÒÇÆ÷Ö÷ÒªÓÃÓÚÊý×Ö²âÁ¿£¬µ«ÊÇËüͬÑù¿ÉÒÔ²úÉú¸÷ÖÖÄ£Äâµ÷ÖÆÐźš£
- SME02\SME03ºÍSME06³ýƵÂÊ·¶Î§Íâ¾ßÓÐÍêÈ«ÏàͬµÄÌØÐÔ¾¼ÃÐÍÐźŷ¢ÉúÆ÷SME03EµÄ¹¦ÄÜÂÔÉÙһЩ¡£ÓÉÓÚÒÇÆ÷¿ÉÒÔ¼Ó×°ÖÖÀà·±¶àµÄÑ¡¼þ£¬ËùÒÔÓû§µÄ¸÷ÖÖÐèÇ󼸺õ¶¼ÄܵÃÒÔÂú×ã¡£
Ö÷ÒªÌØÐÔ
- ÐÔÄÜÖ¸±êpdf
- һ̨ÒÇÆ÷¼´ÄÜÌṩËùÓг£ÓõÄÊý×Öµ÷ÖÆÄ£Ê½¡£
- ÎÞÐèÍⲿµ÷ÖÆÐźÅÔ´ºÍÊý¾ÝÔ´¡£
- Êý¾ÝÐòÁÐÒÔ¼°TDMA½á¹¹¾ù¿ÉÓÉÓû§±à³Ì¡£
- É䯵µÍƵºÍµçƽɨÃè¡£
- ¼«µÍµÄÉäÆµÐ¹Â©¿É±£Ö¤³É¹¦²âÁ¿¸ßÁéÃôѰºô»ú¡£
- Áбí(List)ģʽ: ²âÁ¿ÐòÁпɱà³ÌÔÊÐíÓÐ4096ÖÖÆµÂÊºÍµçÆ½×éºÏ·½Ê½ÉèÖÃʱ¼ä<0.5ms(²»ÊÊÓÃÓÚSME03E)¡£
- Overload protection
- Simultaneous modulation
- Pulse generator
- Flex Protocol
- LF Generator
- DM Mem extension 8-bit
- Rear connectors for RF & LF
- Digital Modulation
- No ext modulation & data source
- User programmable data
| Frequency Range |
5 kHz - 2.2 GHz |
| Frequency Resolution |
0.1 Hz |
| Frequency Switching Time |
10 ms |
| Time base stability |
0.000001 /yr |
| Minimum Output Power |
-144 dBm |
| Maximum Output Power |
13 dBm |
| Power Resolution |
0.1 dB |
| Output Accuracy |
1.5 dB |
| Output Impedance |
50 Ohm |
| Minimum Single-Side-Band Noise |
-140 dBc/Hz |
| Maximum Single-Side-Band Noise |
-126 dBc/Hz |
| Harmonics (noise) |
-30 dBc |
| Non-harmonics (noise) |
-80 dBc |
| Modulation |
AM, FM, FSK, 4FSK, FFSK, GFSK, GMSK, QPSK, ¦Ð/4 DQPSK |
| External Modulation Inputs(Types) |
No |
| User Interface |
Proprietary |
| Ports to Peripheral Devices |
IEEE488,RS232 |
| Test Pattern Storage |
50 Patterns |
| Programming Language |
TDMA |
µç»°: 010 - 62123258 / 62123259 ÓÊÏä: buy17@163.com
