CS2100
CS2100a
Ä£Äâʾ²¨Æ÷
100MHz/2mv/5ns/4×٠˫ʱ»ù
³§¼Ò: ÈÕ±¾½¨Îé
³ß´ç: 30¡Á13¡Á40cm
ÖØÁ¿: 7.4kg
ÐÔÄÜÖ¸±êpdf
o Small and compact with high 5 mV/div sensitivity and 100 MHz bandwidth (1 mV/div when X5 GAIN function is used and 500 MV/div for cascaded operation, CH 1 to CH2).
o Bright 150 mm rectangular CRT with an internal graticule and a 16 kV accelerating potential.
o Vertical axis is capable of single, dual as well as 4-trace display.
o Dual sweep with independent A and B sweeps is provided in addition to single sweep, X10 magnification, delayed sweep and alternating sweep capability.
o Fast 20ns/div sweep speed (2ns/div with X10 magnification).
o A switching type power supply provides stable operation with varying power sources.
o A convenient channel 1 sampling output is provided.
o Gate signal outputs for both A Sweep and B Sweep are provided for use in synchronizing peripheral equipment to these sweeps.
o A convenient beam finder allows you to quickly locate elusive traces.
o Logic controlled switching with LED lighted pushbutton switches provides easy, reliable switching with setting hold capability when the instrument is switched off.
µç»°: 010 - 62123258 / 62123259 ÓÊÏä: buy17@163.com
