Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¶þÊÖÄ£Äâʾ²¨Æ÷ LBO-518
²úÆ·Ãû³Æ£º ¶þÊÖÄ£Äâʾ²¨Æ÷ LBO-518
ÐÍ ºÅ£º LBO518
Ä£Äâʾ²¨Æ÷ LBO-518
100MHz/1mv/2ns/Ë«×٠˫ʱ»ùɨÃè
³§¼Ò: ÈÕ±¾Àû´ï
³ß´ç: 30¡Á15¡Á40 cm
ÖØÁ¿: 10kg
ÐÔÄÜÖ¸±êpdf
The LBO-518 is a 100 MHz oscilloscope with all of the features normally found on a lab-grade scope:Stable operation, dual timebase with sweep delay,flexible triggering facilities, and a bright CRT dis-play with internal graticule. More over, it also has aflat rectangular face, a feature found on few scopesin any price class: it can simultaneously display upto eight traces from four different input signals. In addition to the two vertical input channels, thesignals used to externally trigger the main and de-layed timebases can appear on the CRT display.The alternate sweep mode, which allows the inputsignal to be simultaneously displayed by both themain time base and the delayed timebase, effectively doubles this four-trace display to an eighttrace display.The comprehensive triggering capability of the LBO-518 includes several features that case theproblem of triggering on complex signals; a varietyof frequency-selective coupling filters, a trigger holdoff control, and trigger pickoff that alternates between the two vertical channels! Furthermore,the signal providing trigger to the main timebase can be immediately identified and displayed bypressing a pushbutton.
Ïêϸ½éÉÜ£ºwww.buy17.com
µç»°: 010 - 62123258 / 62123259   ÓÊÏä: buy17@163.com
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
