UNITÓÅÀûµÂUT632Êý×Ö½»Á÷ºÁ·ü±í
²úÆ·¼òÊö
UT632ÊÇÒ»¿î˫ͨµÀÊýÏÔ½»Á÷ºÁ·ü±í¡£¾ßÓвâÁ¿µçѹƵÂÊ·¶Î§¿í£¨5Hz¡«2MHz)£¬ÊäÈë×迹¸ß(≥10MΩ),µçѹ²âÁ¿·¶Î§¿í£¨Á¿³Ì400V£©£¬·Ö±æÂʸߣ¨1μV)ÇÒ²âÁ¿¾«¶È¸ßµÈÓŵ㡣ÄÜÓëPC»ú½øÐÐͨÐÅ£¬´«ËͲâÁ¿Êý¾Ý£¬²¢Í¨¹ýרÓÃÈí¼þ±£´æºÍ´òÓ¡Êý¾ÝºÍÇ÷ÊÆÍ¼¡£ÊÊÓÃÓÚµç×ÓʵÑéÊÒ¡¢ÖÆÔ졢ͨѶ¡¢¿ÆÑе¥Î»¼°Ñ§Ð£¡£
²úÆ·ÌØÐÔ¼°Óŵ㣺
1. ¿ÉÁ½Í¨µÀͬʱ²âÁ¿Í¬Ê±ÏÔʾÊýÏÔ½»Á÷ºÁ·ü±í
2. ¾ßÓвâÁ¿µçѹƵÂÊ·¶Î§¿í£¬UT631£º10Hz~2MHz¡¢UT632£º5Hz~2MHz
3. ÊäÈë×迹£º≥10ΜΩ£¬ÊäÈëµçÈÝ≤47pF
4. ²âÁ¿µçѹ·¶Î§£º400μV~400V
5. ËÄλLCDÊýÏÔ£¬×î´óÏÔʾ4040
6. ·Ö±æÂʸߣ¨1μV£©ÇÒ²âÁ¿¾«¶È¸ß
¼¼ÊõÖ¸±ê
| »ù±¾¹¦ÄÜ |
Á¿³Ì |
»ù±¾¾«¶È |
| ½»Á÷µçѹ (V) |
ƵÂÊ: |
10Hz¡«200Hz |
200Hz¡«500Hz |
1kHz |
500kHz¡«2MHz |
| 4mV |
±(2%+0.1mV) |
±(1%+0.1mV) |
±(1%+15) |
±(2%+0.1mV) |
| 40mV |
±(5%+20) |
±(3%+20) |
±(0.5%+15 |
±(5%+20) |
| 400mV |
±(5%+20) |
±(3%+20) |
±(0.5%+15) |
±(5%+20) |
| 4V |
±(5%+20) |
±(3%+20) |
±(0.5%+15) |
±(5%+20) |
| 40V |
±(5%+20) |
±(3%+20) |
±(0.5%+15) |
±(5%+20) |
| 400V |
±(5%+20) |
±(3%+20) |
±(0.5%+15) |
±(5%+20) |
| ÌØÊ⹦ÄÜ |
| ×î´óÏÔʾ |
4040 |
| ×Ô¶¯Á¿³Ì |
| ƵÏ죨Hz£© |
5Hz¡«2MHz |
| ÔëÒôµçѹ |
≤18¸ö×Ö |
| ˫ͨµÀ |
| USB Êý¾Ý´«Êä |
| ÊäÈë×迹 |
RΛ≥10MΩ CΛ≤47pF |
| Ò»°ãÌØÕ÷ |
| µçÔ´ |
220V±10% »ò 110V±10%(50Hz±4%,7VA) |
| LCD³ß´ç |
157mm X 36mm |
| »úÉíÑÕÉ« |
ºìÉ«+»ÒÉ« |
| »úÉíÖØÁ¿ |
3.0Kg |
| »úÉí³ß´ç |
370mm X 222mm X 106mm |
| ±ê×¼Åä¼þ |
Ë«¼Ð²âÊÔÏß2¸ù¡¢µçÔ´Ïß¡¢USBÊý¾ÝÏß¡¢Èí¼þ¹âÅÌ |
| ±ê×¼°ü×° |
²ÊºÐ¡¢ËµÃ÷Êé¡¢±£ÐÞ¿¨ |
| ±ê×¼°ü×°ÊýÁ¿ |
4̨ |
| ±ê×¼°ü×°³ß´ç |
690mm X 455mm X 320mm |
| ±ê×¼°ü×°ÏäÃ«ÖØ |
21Kg |
