²úÆ·Ãû³Æ£º
̨ÍåMOXA½»»»»úÎÞÏßAPÄ£¿é µÈÌØ¼Û¹©Ó¦
ÐÍ ºÅ£º
EDS-408A-SS-SC-T
̨ÍåMOXA ½»»»»ú ¹âµçת»»Æ÷ ¹âÏËת»»Æ÷ ÎÞÏßAP ·ÓÉÆ÷ ´®¿Ú¿¨ Íø¹Ø ´®¿Ú·þÎñÆ÷ Ä£¿é ȫϵÁÐÌØ¼Û¹©Ó¦£¬´óÁ¿ÏÖ»õ È«ÐÂÔ×°°üº¬Ë°ÔË ÎåÄêÖʱ£ 10/100BaseT(X) ¶Ë¿Ú£¨RJ45 ½ÓÍ·£©
EDS-408A/408A-T£¬EDS-408A-EIP/PN ϵÁУº8
EDS-408A-MM-SC/MM-ST/SS-SC ϵÁУº6
EDS-408A-3M-SC/3M-ST/3S-SC/3S-SC-48/1M2S-SC/2M1S-SC ϵÁУº5
ËùÓÐÐͺžùÖ§³Ö£º
ËÙÂÊ×ÔÊÊÓ¦
È«/°ëË«¹¤Ä£Ê½
×Ô¶¯ MDI/MDI-X Á¬½Ó
100BaseFX ¶Ë¿Ú£¨¶àÄ£ SC ½ÓÍ·£©
EDS-408A-MM-SC/2M1S-SC ϵÁУº2
EDS-408A-3M-SC ϵÁУº3
EDS-408A-1M2S-SC ϵÁУº1
100BaseFX ¶Ë¿Ú£¨¶àÄ£ ST ½ÓÍ·£©
EDS-408A-MM-ST ϵÁУº2
EDS-408A-3M-ST ϵÁУº3
100BaseFX ¶Ë¿Ú£¨µ¥Ä£ SC ½ÓÍ·£©
EDS-408A-SS-SC/1M2S-SC ϵÁУº2
EDS-408A-2M1S-SC ϵÁУº1
EDS-408A-3S-SC/3S-SC-48 ϵÁУº3
±ê×¼
IEEE 802.3£¬ÓÃÓÚ 10BaseT
IEEE 802.3u£¬ÓÃÓÚ 100BaseT(X) ºÍ 100BaseFX
IEEE 802.3x£¬ÓÃÓÚÁ÷Á¿¿ØÖÆ
IEEE 802.1D-2004£¬ÓÃÓÚÉú³ÉÊ÷ÐÒé (STP)
IEEE 802.1p£¬ÓÃÓÚ·þÎñµÈ¼¶
IEEE 802.1Q£¬ÓÃÓÚ VLAN ±ê¼Ç
IEEE 802.1w£¬ÓÃÓÚ¿ìËÙÉú³ÉÊ÷ÐÒé (RSTP)
¹âÏË
ÒÔÌ«ÍøÈí¼þÌØÐÔ
¹ýÂË
802.1Q VLAN¡¢GMRP¡¢GVRP¡¢IGMP v1/v2¡¢»ùÓÚ¶Ë¿ÚµÄ VLAN
¹¤ÒµÐÒé
EtherNet/IP¡¢Modbus TCP¡¢EDS-408A-PN ϵÁУºPROFINET IO Device (Slave)
¹ÜÀí
Back Pressure Flow Control£¨±³Ñ¹Á÷Á¿¿ØÖÆ£©¡¢BOOTP¡¢DHCP Option 66/67/82¡¢DHCP Server/Client¡¢Flow control£¨Á÷Á¿¿ØÖÆ£©¡¢IPv4/IPv6¡¢LLDP¡¢Port Mirror£¨¶Ë¿Ú¾µÏñ£©¡¢RARP¡¢RMON¡¢SMTP¡¢SNMP Inform¡¢SNMPv1/v2c/v3¡¢Syslog¡¢Telnet¡¢TFTP
MIB
Bridge MIB¡¢Ethernet-like MIB¡¢MIB-II¡¢P-BRIDGE MIB¡¢RMON MIB Groups 1¡¢2¡¢3¡¢9¡¢RSTP MIB
ÈßÓàÐÒé
RSTP¡¢STP¡¢Turbo Chain¡¢Turbo Ring v1/v2
¶Ôʱ·þÎñ
NTP Server/Client¡¢SNTP
½»»»ÌØÐÔ
IGMP ·Ö×é
256
MAC µØÖ·±í´óС
8 K
×î´ó VLAN ÊýÁ¿
64
Êý¾Ý°ü»º³åÇø´óС
1 Mb
ÓÅÏȼ¶¶ÓÁÐ
4
VLAN ID ·¶Î§
VID 1 ÖÁ 4094
´®¿Ú½çÃæ
DIP ¿ª¹ØÅäÖÃ
ÊäÈë/Êä³ö½Ó¿Ú
µçÔ´²ÎÊý
Á¬½Ó
1 ¸ö¿É²ðж 6 ´¥µã½ÓÏß¶Ë×Ó
ÊäÈëµçѹ
ËùÓÐÐͺţºÈßÓàË«µçÔ´ÊäÈë
EDS-408A/408A-T¡¢EDS-408A-MM-SC/MM-ST/SS-SC/3M-SC/3M-ST/3S-SC/1M2S-SC/2M1S-SC/EIP/PN ϵÁУº12/24/48 VDC
EDS-408A-3S-SC-48/408A-3S-SC-48-T£º±24/±48 VDC
¹¤×÷µçѹ
EDS-408A/408A-T¡¢EDS-408A-MM-SC/MM-ST/SS-SC/3M-SC/3M-ST/3S-SC/1M2S-SC/2M1S-SC/EIP/PN ϵÁУº9.6 ÖÁ 60 VDC
EDS-408A-3S-SC-48 ϵÁУº
±19 ÖÁ ±60 VDC
ÊäÈëµçÁ÷
EDS-408A/408A-T£¬EDS-408A-EIP/PN ϵÁУº0.18 A @ 24 VDC
EDS-408A-MM-SC/MM-ST/SS-SC ϵÁУº0.30 A @ 24 VDC
EDS-408A-3M-SC/3M-ST/3S-SC/3S-SC-48/1M2S-SC/2M1S-SC ϵÁУº0.35 A @ 24 VDC
¹ýÔØµçÁ÷±£»¤
Ö§³Ö
·´½Ó±£»¤
Ö§³Ö
»úÐµÌØÐÔ
Íâ¿Ç
½ðÊô
IP µÈ¼¶
IP30
³ß´ç
53.6 x 135 x 105 mm£¨2.11 x 5.31 x 4.13 Ó¢´ç£©
ÖØÁ¿
EDS-408A/408A-T¡¢EDS-408A-MM-SC/MM-ST/SS-SC¡¢EDS-408A-EIP/PN ϵÁУº650 g (1.44 lb)
EDS-408A-3M-SC/3M-ST/3S-SC/3S-SC-48/1M2S-SC/2M1S-SC ϵÁУº890 g (1.97 lb)
°²×°
µ¼¹ìʽ°²×°£¬±Ú¹Òʽ°²×°£¨´ø¿ÉÑ¡Ì×¼þ£©
¹¤×÷»·¾³
°²¹æÈÏÖ¤
°²È«
ËùÓÐÐͺţºEN 60950-1¡¢UL 508
EDS-408A/408A-T¡¢EDS-408A-MM-SC/MM-ST/SS-SC ϵÁС¢EDS-EIP/PN ϵÁУºUL 60950-1
EMC
EN 55032/24
EMI
CISPR 32£¬FCC Part 15B Class A
EMS
IEC 61000-4-2 ESD£º½Ó´¥£º6 kV£»¿ÕÆø£º8 kV
IEC 61000-4-3 RS£º80 MHz ÖÁ 1 GHz£º10 V/m
IEC 61000-4-4 EFT£ºµçÔ´£º2 kV£»Ðźţº2 kV
IEC 61000-4-5 Surge£ºµçÔ´£º2 kV£»Ðźţº2 kV
IEC 61000-4-6 CS£º10 V
IEC 61000-4-8 PFMF
º£ÊÂ
EDS-408A/408A-T¡¢EDS-408A-MM/SS ϵÁУºNK
EDS-408A/408A-T¡¢EDS-408A-MM/SS ϵÁС¢EDS-408A-EIP/PN ϵÁУºDNV-GL
¹ìµÀ½»Í¨
EN 50121-4
½»Í¨¿ØÖÆ
NEMA TS2
×ÔÓÉÂäÌå
IEC 60068-2-31
³å»÷
IEC 60068-2-27
Õñ¶¯
IEC 60068-2-6
MTBF
ʱ¼ä
EDS-408A/408A-T£¬EDS-408A-EIP/PN ϵÁУº1,339,439 Сʱ
EDS-408A-MM-SC/MM-ST/SS-SC/3M-SC/3M-ST/3S-SC/1M2S-SC/2M1S-SC ϵÁУº1,253,072 Сʱ
EDS-408A-3S-SC-48 ϵÁУº989,940 Сʱ
±ê×¼
Telcordia (Bellcore)£¬GB
±£ÐÞ
±£ÐÞÆÚÏÞ
5 Äê
