| System |
| CPU |
Intel µFC-LGA 775 socket supports Core 2 Duo/ Pentium D/ Pentium 4/ Celeron D with 65nm process technology |
| FSB |
1066/800/533 MHz
| BIOS |
Award 4 Mb Flash ROM BIOS
| System Chipset |
Intel 945G GMCH/ ICH7R DH
| I/O Chip |
Winbond W83627EHG-A
| System Memory |
4 240-pin DIMM sockets support up to 4 GB Dual Channel DDR2 667/533 SDRAM |
| Watchdog Timer |
KBMS Reset: 1 to 255 sec/min |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
| SmartFan Control |
Speed Cruise Mode
| Expansion |
1 PCI-E x16, 1 PCI-E x1, 5 PCI slots (PCI Rev. 2.2 compliant) |
| I/O |
| MIO |
2 EIDE (Ultra DMA 100), 4 SATA II, 1 FDD, 1 LPT, 3 RS-232, 1 RS-232/422/485, 1 K/B, 1 Mouse |
| USB |
8 USB 2.0 |
| Display |
| Chipset |
Intel 945G GMCH integrated Graphics Media Accelerator 950
| Display Memory |
Intel DVMT 3.0 supports 224 MB video memory |
| Max. Resolution |
2048 x 1536 @ 32 bpp (75 Hz) |
| VGA Interface |
PCI-E x16 VGA interface |
| LVDS |
Through ADD2 LVDS Card (Customized BIOS required)
| DVI |
Through ADD2 DVI Card (Customized BIOS required)
| TV-OUT |
Through ADD2 TV-Out Card (Customized BIOS required)
| Audio |
| Chipset |
Intel ICH7R DH
| Azalia Codec |
Realtek ALC 888, 5.2 + 2 CH High Definition Audio |
| Audio Interface |
Mic-in, Line-in, CD Audio-in, Line-out, S/PDIF Out |
| Ethernet |
| LAN 1 |
Intel 82573L Gigabit LAN
| LAN 2 |
| Back Panel I/O Port |
1 PS/2 Keyboard 1 PS/2 Mouse 1 Parallel port 1 Serial port 1 VGA port 2 RJ45 ports 4 USB ports Audio I/O (3 jacks) |
| Internal I/O Connector |
2 USB connectors support additional 4 USB ports 1 24-pin ATX Power connector 1 4-pin ATX 12V Power connector 1 Floppy disk drive connector 2 IDE connector for two devices 3 COM connectors 1 Chassis intrusion connector 1 CD audio in connector 1 TPM connector 4 SATA connectors 1 Front panel audio connector 1 S/PDIF out connector 1 Speaker connector 1 System panel connector 1 3-pin Power LED connector 1 CPU Fan connector 1 Chassis Fan connector 1 Power Fan connector |
| Mechanical & Environmental |
| Power Requirement |
+5 V @ 4.26 A, +12 V @ 10.12 A, +3.3 V @ 722 mA (with Intel Core 2 Duo E6400 2.13 GHz & 2 x 1 GB DDR2 SDRAM) |
| Power Type |
ATX
| Operating Temperature |
0 to 60°C (32 to 140°F)
| Operating Humidity |
0% to 90% relative humidity, non-condensing
| Size (L x W) |
12" x 9.6" (304.8 mm x 243.84 mm)
| Weight |
1.32 lbs (0.6 Kg) |
