| Expansion |
| Add-on Card |
1 x PCIe Full-height / half-length slot |
| Hark Disk Drive |
1 x 2.5" HDD (Internal, IDE/SATA) |
| SSD |
1 x Type I/II CF slot on bottom |
| External I/O |
| Rear Panel |
Depends on system Motherboard |
| Front Panel |
1 x PWR SW, 2 x USB, 2 x LED (PWR/HDD) |
| Optional Knock-out |
2 x COM |
| Power Supply Unit |
| Power Input |
100 ~240 V / 50 ~ 60 Hz (Adapter) |
| Power Output |
200 W |
| Mechanical & Environmental |
| Operating Temperature |
0~40°C (32~104°F) |
| Relative Humidity |
5 to 90% @ 40°C (104°F), non-condensing |
| I/O Shield |
Standard ATX I/O opening |
| Mounting |
Desk / Wall (wall-mount bracket in option) |
| Weight |
7.71 lbs / 3.5 Kgs |
| Dimensions (WxHxD) |
W300 x H72 x D220 mm W350 x H84 x D220 mm (w / bracket) |
