| 产品名称: |
Nano ITX NX15MXL
| 型 号: |
NX15MXL |
| 价 格: |
0.00 |
| 品 牌: |
必升 |
产品介绍: |
Intel® Atom™ processor Z510P 1.1GHz/Z530P 1.6GHz (400/533 MT/s MHz FSB) |
Intel® System Controller Hub US15WP |
One 200-pin SO-DIMM 2 GB DDR2 400/533 org.x16 SDRAM |
1 VGA (By Chrontel CH7317), 1 LVDS |
Realtek ALC 888, 5.1+2 Channel High Definition Audio Codec (co-lay ALC 888VC) |
Realtek RTL 8111C Gigabit LAN |
1 Mini PCI-E, 1 CF |
4 USB (2 connectors, 1 pin header), 1 COM port header, 1 PATA interface 1 Chassis Fan header |
8-bit GPIO (4 in, 4 out), Clock (CK540) |
Specifications
| System |
| CPU |
Intel® Atom™ processor Z510P 1.1GHz/Z530P 1.6GHz |
| FSB |
400/533 MHz |
| BIOS |
Award 8 Mb FHW BIOS |
| System Chipset |
| I/O Chip |
Winbond W83627DHG |
| System Memory |
1 x 200-pin SODIMM 2 GB DDR2 400/533 org.x16 SDRAM |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
1 x Mini PCIe/1 x CF |
| Wake up on LAN/Ring |
8-bit General Purpose I/O for 4 DI and 4 DO |
| S3/S4 |
Yes |
| Wake up on LAN or Ring |
Both (PXE / RPL ) |
| SmartFan Control |
Chassis Fan |
| Display |
| Chipset |
| Display Memory |
Intel® Graphics Media Accelerator 500 (Intel® GMA 500) |
| Max Resolution |
LVDS Display : 1366 x 768 @85 MHz Ext Display: 1280 x 1024 @ 85 Hz maximum resolution |
| Dual Display |
Yes , LVDS+VGA |
| VGA |
Yes |
| LVDS |
Yes, 18/24 bit Single Channel |
| LVDS Backlight Power |
Yes |
| Audio |
| Audio Codec |
Realtek ALC 888 (co-lay ALC 888VC) |
| Audio Interface |
Mic in , Line out ( 2 jack ) , Line in pin header |
| Ethernet |
| LAN 1 |
| Back Panel I/O Port |
1X PS2(KB+MS) / 1 x VGA port / 2 x USB 2.0/1.1 /1 x LAN RJ45 port / 1 x Audio Mic in (1 jack) /1 x Audio Line out (1 jack) |
| Internal I/O Connector |
* 1 x USB connectors support additional 2 USB ports * 1 x 6-pin ATX Power connector * 1 x COM port pin header * 1 x LVDS connector * 1 x Chasis FAN connector * 1 x GPIO connector * 1 x PATA interface |
| Mechanical & Environmental |
| Power Type |
ATX |
| Operating Temperature |
0-60°C(32-104°F) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
4.72" x 4.72" (120 mm x 120 mm) |
| Weight |
0.3 lbs(0.14Kg) |
| Ordering Information |
NX15MXL
Intel Atom™ processor Z510P 1.1GHz/Z530P 1.6GHz Nano ITX Motherboard with VGA,LVDS,Audio, LAN, Mini PCIe, CF, 1 COM, 1 PATA,4 USB & 8-bit DIO |
| 关 键 词: |
嵌入式主板 NX15MXL |
