| 产品名称: |
ATX AX45Q2
| 型 号: |
AX45Q2 |
| 价 格: |
0.00 |
| 品 牌: |
产品介绍: |
Intel® Q45 LGA775 Socket for Intel® Core™ 2 Quad / Core™ 2 Duo Processors. Support Intel® Next Generation 45nm Multi-Core CPU |
Intel Q45 / ICH10DO |
Support four DIMM, max. 8GB, DDR3 800/1066, non-ECC, un-buffered memory. |
Intel Graphics Media Accelerator 4500 Integrated |
Realtek ALC888, 7.1 with Multiple Streaming HD Audio |
Dual Realtek RTL 8111SC Gigabit LAN |
2 x PCI-E 2.0x16 / 1 x PCI / 4 x PCI-Ex1 |
1 x COM, RS232/422/485 Configured by Jumper Setting / 12 x USB 2.0 / 5x SATA/SATAII / 1 x eSATA/1 x PS2 MS/KB |
Power Fail Auto on |
Specifications
| System |
| CPU |
Intel® Q45 LGA775 Socket for Intel® Core™ 2 Quad / Core™ 2 Duo Processors. Support Intel®Next Generation 45nm Multi-Core CPU |
| FSB |
1333/ 1066 / 800 MHz |
| System Chipset |
Intel® Q45 GMCH/ICH10DO |
| BIOS |
AMI 32 Mb BIOS |
| I/O Chip |
Winbond W83627DHG-A |
| System Memory |
Four 240-pin DIMM sockets support up to 8 GB, DDR3 800/1066 |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
2 x PCI-E 2.0x16(IDT 24 LAN Switch) 1 x PCI 4 x PCI-Ex1 |
| DIO |
16Bit (8 in 8out) |
| S3/S4 |
Yes |
| TPM |
Integrated iTPM 1.2 |
| Wake up on LAN or Ring |
LAN (PXE / RPL) |
| SmartFan Control |
Yes |
| Display |
| Chipset |
| Display Memory |
Intel DVMT 4.0 supports up to 384MB video memory |
| Max. 3D Resolution |
2048 x 1536 @ 32 bpp (75Hz) |
| VGA |
on board |
| Audio |
| Audio Codec |
Realtek® ALC888, 5.1 +2 CH with Two Independent Streaming |
| Audio Interface |
Mic-in, Rear Speaker-out |
| Ethernet |
| LAN 1 |
| LAN 2 |
| Back Panel I/O Port |
1 x VGA Port / 4 x USB 2.0/1.1 Port /1 x COM,RS232/422/485 Configured By Jumper Setting /2 x RJ45 Port / 1 x PS2 KB/MS/ 1 x eSATA Port /1 x Audio Jack(Mic in/Line in/Line out) |
| Internal I/O Connector |
*5 x SATA Connectors *4 x USB Connectors Support Additional 8 USB Ports (with 5V dual) *1 x COM Header *1 x CPU Fan Connector *1 x Chassis Fan Connector *1 x Power Fan Connector *1 x Front Panel Header *1 x Chassis Intrusion Header *1 x 24-pin ATX Power Connector *1 x 4-pin ATX 12V Power Connector |
| Mechanical & Environmental |
| Power Type |
ATX |
| Operating Temperature |
0~60°C (32~140°F) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
12" x 9.6" (304.8 mm x 243.84 mm) |
| Weight |
1.32 lbs (0.6 Kg) |
| Ordering Information |
AX45Q2
Intel® Q45 LGA775 Core™2 Quad ATX Motherboard with VGA, Audio, Dual Gb LAN,2 COM, 8 USB, 2 PCI-Ex16, 4 PCI-Ex1, 1 PCI,16-bit DIO, iTPM | |
| 关 键 词: |
嵌入式主板 AX45Q2 |
