| 产品名称: |
ATX AX45Q
| 型 号: |
AX45Q |
| 价 格: |
0.00 |
| 品 牌: |
必升 |
产品介绍: |
Intel® Q45 LGA775 Socket for Intel® Core™ 2 Quad/ Core™ 2 Duo Processors. Support Intel® Next Generation 45nm Multi-Core CPU |
Intel Q45 / ICH10DO |
Support four DIMM, Max. 8GB, DDR2 667/800 MHz,Non-ECC, Un-buffered Memory |
Intel® Graphics Media Accelerator 4500 Integrated |
Realtek® ALC888, 7.1 with Multiple Streaming HD Audio |
Dual Realtek RTL 8111SC Gigabit LAN |
1 x PCI-E 2.0 x16, 2 x PCI-E x1, 2 x PCI 2.3 32/64bit 33/66MHz (TI Bridge),2 x PCI 2.3 33MHz(South Bridge) |
2 x COM, 12 x USB 2.0, 5 x SATA/SATA II , 1 x eSATA |
Power Fail Auto On |
Specifications
| System |
| CPU |
Intel® Q45 LGA775 Socket for Intel® Core™ 2 Quad / CoreTM 2 Duo Processors. Support Intel® Next Generation 45nm Multi-Core CPU |
| FSB |
1333 / 1066 / 800 MHz |
| BIOS |
AMI 32Mb BIOS |
| System Chipset |
Intel Q45 GMCH/ICH10DO |
| System Memory |
Four 240-pin DIMM sockets support up to 8 GB, DDR2 800 / 667 MHz |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
1 x PCI-E 2.0 x16 / 2 x PCI-E x1/2 x PCI 2.3 32/64bit 33/66MHz (TI Bridge)/2 x PCI 2.3 33MHz (South Bridge) |
| DIO |
16Bit (8 in 8out) |
| TPM |
Intergrated iTPM 1.2 |
| S3/S4 |
Yes |
| Wake up on LAN or Ring |
LAN (PXE / RPL) |
| SmartFan Control |
Yes |
| Display |
| Chipset |
Intel Q45 GMCH integrated Graphics Media Accelerator 4500 |
| Display Memory |
Intel DVMT 4.0 supports up to 384MB video memory |
| Max. 3D Resolution |
2048 x 1536 @ 32 bpp (75Hz) |
| VGA |
on board |
| Audio |
| Audio Codec |
Realtek ALC888, 5.1 +2 CH with Two Independent Streaming |
| Audio Interface |
Mic-in, Rear Speaker-out |
| Ethernet |
| LAN 1 |
| LAN 2 |
| Back Panel I/O Port |
1 x VGA port / 1 x COM port(RS-232/422/485)/2 x RJ45 port / 4 x USB 2.0/1.1 port/1 x eSATA port / 1 x Audio Jack (2 port) / 1 x PS2 KB/MS |
| Internal I/O Connector |
*5 x SATA connectors *4 x USB connectors support additional 8 USB ports (with 5V dual) *1 x COM header(RS-232/422/485) *1 x CPU Fan connector *1 x Chassis Fan connector *1 x Power Fan connector *1 x Front panel header *1 x Chassis Intrusion header *1 x 24-pin ATX Power connector *1 x 4-pin ATX 12V Power connector |
| Mechanical & Environmental |
| Power Type |
ATX |
| Operating Temperature |
0~60°C (32~140°F) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
12" x 9.6" (304.8 mm x 243.84 mm) |
| Weight |
1.32 lbs (0.6 Kg) |
| Ordering Information |
AX45Q
Intel Q45 LGA775 CoreTM2 Quad ATX Motherboard with 1 x PCI-E 2.0 x16, 2 x PCI-E x1,4 x PCI 2.3, 2 x COM, 12 x USB 2.0,4 x SATA/SATAII, 1 x eSATA, 16-bit DIO, & iTPM |
| 关 键 词: |
嵌入式主板 AX45Q |
