SQF-SHM 630 SATA III (6.0Gb) Half-Size mSATA
Features
ƒ Half-Size Mini PCIe Form Factor
ƒ Interface: SATA Gen. 3
ƒ Supports 72 bit ECC correct per 1K Byte data
ƒ Universal wear-leveling and bad block management
ƒ Shock resistance, anti-vibration and low power consumption
ƒ GUI management tool & software API package
Specifications
Connector Type Mini PCIe 52pin connector with SATA pin-out
Flash type SLC / Ultra MLC / MLC
Capacity
SLC: 1 to 32GB
Ultra MLC: 4 to 32GB
MLC: 4 to 64GB
Transfer Mode SATA III (6.0 Gbps)
Sustained R/W
Performance (*)
SLC: up to 130/100 MB/sec
MLC: up to 250/100 MB/sec
Operating Temperature Commercial grade: 0 to +70° C
Industrial grade: -40 to +85° C
Shock Resistance 1,500 G, peak / 0.5 ms
Vibration Resistance 20 G, peak / 80 ~ 2000 Hz
Endurance 2,000,000 program/erase cycles
Dimensions (mm) 26.8 x 30 x 4.2
Ordering Information
PN Description
SQF-SHMS1-1G-S9C SQFlash 630 series HS mSATA SLC, DMA, 1 GB (0 ~ 70° C)
SQF-SHMS1-1G-S9E SQFlash 630 series HS mSATA SLC, DMA, 1 GB (-40 ~ 85° C)
SQF-SHMS2-XG-S9C SQFlash 630 series HS mSATA SLC, DMA, 2/4/8/16/32 GB
(0 ~ 70° C)
SQF-SHMS2-XG-S9E SQFlash 630 series HS mSATA SLC, DMA, 2/4/8/16/32 GB
(-40 ~ 85° C)
SQF-SHMU2-XG-S9C SQFlash 630 series HS mSATA Ultra MLC, DMA, 4/8/16/32
GB (0 ~ 70° C)
SQF-SHMU2-XG-S9E SQFlash 630 series HS mSATA Ultra MLC, DMA, 4/8/16/32 GB
(-40 ~ 85° C)
SQF-SHMM1-4G-S9C SQFlash 630 series HS mSATA MLC, DMA, 4 GB (0 ~ 70° C)
SQF-SHMM1-4G-S9E SQFlash 630 series HS mSATA MLC, DMA, 4 GB (-40 ~ 85° C)
SQF-SHMM2-XG-S9C SQFlash 630 series HS mSATA MLC, DMA, 8/16/32/64 GB
(0 ~ 70° C)
SQF-SHMM2-XG-S9E SQFlash 630 series HS mSATA MLC, DMA, 8/16/32/64 GB
(-40 ~ 85° C)
