Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÓîÕ°DOMµç×ÓÅÌ
²úÆ·Ãû³Æ£º ÓîÕ°DOMµç×ÓÅÌ
ÐÍ ºÅ£º AS33-008GCD00M
¼ò½é
Apacer ATA Disk Module (ADM) complies with 44 / 40 PIN IDE (ATA) standard interface in horizontal type or in vertical type. With high capacity of flash memory supporting, and is suitable for data storage media and code storage device for embedded system, mobile computing devices or other electronic equipments.
100% Compatible with the Standard IDE ATA interface, Apacer ATA Disk Module (ADM) works exactly like a standard hard drive but without any moving part, strongly increasing reliability and improving data access speed performance, without any noise.
Í»³öÏÔʾ
Standard 40-pin IDE female connector
Housing solution
Built-in HW ECC, Quick Erase and SMART Functions
Advanced Wear-leveling and Block Management
Power Failure Recovery
Secured Protection Zone (Optional)
Dimensions: 50.93(L)x25.91(W)x6.34(H)mm
¹æ¸ñ
ÐͺŠADMIII 40P/90D
½Ó¿Ú Standard ATA / IDE
Á¬½ÓÆ÷ 40-pin (2.54mm pitch)
´«ËÍģʽ PIO Mode-4 ; MWDMA Mode-2 UDMA Mode-4
NANDÉÁ´æÀàÐÍ SLC
ÈÝÁ¿ 128MB~16GB
³ÖÐø¶ÁÈ¡ÄÜÁ¦(MB/Ãë) Standard:Up to 20;High Speed:Up to 35
³ÖÐøÐ´ÈëÄÜÁ¦(MB/Ãë) Up to 10
ECCÖ§³Ö Up to 8 bit correction per 512bytes (BCH)
±ê×¼¹¤×÷ÎÂ¶È 0 ~ + 70
À©Õ¹¹¤×÷ÎÂ¶È ( °C ) -40~ + 85
´æ´¢ÎÂ¶È -40~ + 100
³å»÷ 50G
Õñ¶¯ 15G
ʪ¶È 5%~95%
¹¤×÷µçѹ 3.3V / 5V
µÍ¹¦ºÄ Active mode: 85mA/95mA (3.3V/5V);Sleep mode: 500μA /600μA (3.3V/5V)
MTBF (hours) >2,000,000
³ß´ç(mm) 50.93(L)x25.91(W)x6.34(H)
Product Type 40P/90D
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÁªÀÖʵҵÓÐÏÞ¹«Ë¾
µç »°£º 0755 88377841-805 / ÅíÔ°Ô°
ÊÖ»ú£º 13925562745
µØ Ö·£º ¸£ÌïÇø²ÊÌﷲʺç´óÏÃ25AB
ÓÊ ±à£º 518016
Ö÷ Ò³£º http://www.univo.com.cn
  • ÓîÕ°DOMµç×ÓÅÌADMIII 40P/180D
  • ÓîÕ°DOMµç×ÓÅÌ
  • Ñлª¹¤Òµ¼¶¹Ì̬ӲÅÌSQF-SHM 630 SATA III (6.0Gb)
  • Ñлª¹¤Òµ¼¶SSD
  • Ñлª¹¤Òµ¼¶¹ÌÌåÓ²ÅÌSQF-S25 820 SATA III (6.0Gb)
  • PQI¹¤ÒµCF¿¨
  • INNODISK ¹¤Òµ¿íÎÂCF¿¨
  • INNODISK ¹¤Òµ¼¶ 4000ϵÁÐ ICF
  • INNODISK 2.5" SSD (ATA Mirror Disk )
  • PQI ¹¤Òµ¼¶SATA SSD 2.5" 64G
