SQF-SHM 520 SATA II (3.0Gb) Half-Size Msata
Features
Half-Size Mini PCIe Form Factor
Interface: SATA Gen. 2
Supports 44 bit ECC correct per 1K Byte data
Universal wear-leveling and bad block management
Shock resistance, anti-vibration and low power consumption
GUI management tool & software API package
Specifications
Connector Type Mini PCIe 52pin connector with SATA pin-out
Flash type SLC / MLC
Capacity SLC: 1G to 16G
MLC: 4G to 32G
Transfer Mode SATA II (3.0 Gbps)
Sustained R/W
Performance (*)
SLC: up to 35/30 MB/sec
MLC: up to 30/20 MB/sec
Operating Temperature Commercial grade: 0 to +70° C
Industrial grade: -40 to +85° C
Shock Resistance 1,500 G, peak / 0.5 ms
Vibration Resistance 20 G, peak / 80 ~ 2000 Hz
Endurance 2,000,000 program/erase cycles
Dimensions (mm) 26.8 x 30 x 4.2
Ordering Information
PN Description
SQF-SHMS1-XG-S7C Advantech SQFlash HS mSATA SLC, DMA,
1/2/4/8/16 GB, (0 ~ 70° C)
SQF-SHMS1-XG-S7E Advantech SQFlash HS mSATA SLC, DMA,
1/2/4/8/16GB, (-40 ~ 85° C)
SQF-SHMM1-XG-S7C Advantech SQFlash HS mSATA MLC, DMA, 4/8/16/32
GB, (0 ~ 70° C)
SQF-SHMM1-XG-S7E Advantech SQFlash HS mSATA MLC, DMA, 4/8/16/32
GB, (-40 ~ 85° C)
