SQF-S25 820 SATA III (6.0Gb) 2.5" SSD
Features
Compliant with SATA III and SATA v3.0 standard
Supports 72 bit ECC correct per 1K Byte data
Supports Fragment Writing and Flush Manager
Shock resistance, anti-vibration and Low power consumption
GUI Management Tool & Software API Package
Specifications
Connector Type Standard 7+15-pin SATA connector
Flash Type SLC / MLC
Capacity SLC: 16 to 256 GB
MLC: 16 GB to 1 TB
Transfer Mode SATA III (6.0 Gbps)
Sustained R/W
Performance (*) SLC and MLC up to 500/350 MB/sec
Operating Temperature Commercial Grade: 0 to +70° C
Industrial Grade: -40 to +85° C
Shock Resistance 1,500 G, Peak / 0.5 ms
Vibration Resistance 20 G, Peak / 80 ~ 2000 Hz
Dimensions (mm) 100.20 x 69.85 x 7
Ordering Information
Part No. Product Description
SQF-S25S4-16G-S8C SQFlash 820 series 2.5" SSD SLC 16G (0 ~ 70° C)
SQF-S25S4-16G-S8E SQFlash 820 series 2.5" SSD SLC 16G (-40 ~ 85° C)
SQF-S25S8-XG-S8C SQFlash 820 series 2.5" SSD SLC 32/64/128/256G
(0 ~ 70° C)
SQF-S25S8-XG-S8E SQFlash 820 series 2.5" SSD SLC 32/64/128/256G
(-40 ~ 85° C)
SQF-S25M4-16G-S8C SQFlash 820 series 2.5" SSD MLC 16G (0 ~ 70° C)
SQF-S25M4-16G-S8E SQFlash 820 series 2.5" SSD MLC 16G (-40 ~ 85° C)
SQF-S25M5-XG-S8C SQFlash 820 series 2.5" SSD MLC 40/80/160G
(0 ~ 70° C)
SQF-S25M5-XG-S8E SQFlash 820 series 2.5" SSD MLC 40/80/160G
(-40 ~ 85° C)
SQF-S25M8-X-S8C SQFlash 820 series 2.5" SSD MLC
32/64/128/256/512G/1T (0 ~ 70° C)
SQF-S25M8-X-S8E SQFlash 820 series 2.5" SSD MLC
32/64/128/256/512G/1T (-40 ~ 85° C)
