NPS系列驱动器主要分为两大类:NPS-FI(主要用于中空轴电机,高速电机, 异步电机) ; NPS-FS(主要用于同步电机)此种驱动器带有控制功能,所以也可称为控制器,他们只能控制一轴,三种控制方式:位置控制;速度控制;力矩控制
型号:NPS-FIMA401,NPS-FIMA801,NPS-FIMA122,NPS-FIMA242,NPS-FIMA402,NPS-FIMA752,NPS-FIMA113,NPS-FIMA153,NPS-FIMA223,NPS-FIMA303,NPS-FIMA373(可配电机系列:NA20,NA30,NA100)
型号:NPS-FIHA113,NPS-FIHA153,NPS-FIHA223,NPS-FIHA303,NPS-FIHA373,NPS-FIHA553,NPS-FIHA753,NPS-FIHA114,NPS-FIHA154,NPS-FIHA224(可配电机系列:NA20,NA30,NA100)
型号:NPS-FSMA122,NPS-FSMA242,NPS-FSMA402,NPS-FSMA752,NPS-FSMA113,NPS-FSMA153,NPS-FSMA223,(可配电机系列:NA720)
Item |
Unit Type |
NA30
-13F-15 |
NA30
-25F-15 |
NA30
-50F-15 |
NA30
-110F-15 |
NA30
-180F-15 |
Rated output |
kW |
0.2 |
0.4 |
0.8 |
1.6 |
2.8 |
Rated torque |
Nm |
1.27 |
2.55 |
5.10 |
10.19 |
17.84 |
Rated speed |
rpm |
1500 |
1500 |
1500 |
1500 |
1500 |
Rated current |
A |
1.7 |
3.4 |
6.4 |
13 |
22 |
max. torque |
Nm |
6.37 |
12.74 |
25.48 |
50.96 |
89.18 |
Power rate |
kW/s |
16.99 |
23.10 |
16.99 |
23.10 |
38.57 |
Rotor inertia |
kgfms2 |
0.000026 |
0.000064 |
0.000156 |
0.000459 |
0.000842 |
Weight |
Standard motor |
kg |
3.7 |
6.0 |
11.0 |
18.0 |
27.0 |
Driver |
NPS-FIM |
401 |
401 |
801 |
242 |
402 |
NCS-FI*M |
401 |
401 |
801 |
242 |
402 |
更多详细参数,资料,图纸请咨询我司销售人员; |
