产品名称: nikkidenso伺服电机
型  号: NA80
品  牌: 日机电装nikki denso
日机伺服电机NA80系列
NIKKI DENSO 伺服电机
同步式交流伺服电机NA80系列,功率范围包括从50瓦至750瓦(3000转)。他们配备了17bit编码器,它可以转换为绝对编码器。从50W到400W电机可用于VPS系列新型多功能伺服驱动器,使NA80系列表现出其最佳性能。
日机伺服电机
Servo motor type
NA80-05
NA80-10
NA80-20
NA80-20
NA80-40
NA80-60
NA80-75
Power voltage
V
AC100V
AC200V
Motor frange size
mm
40
60
60
80
Reted output
W
200
200
400
600
750
Reted torque
N.m
0.159
0.318
0.64
0.64
1.27
1.91
2.39
Kgf.cm
1.62
3.25
6.5
6.5
13.0
19.5
24.4
Peak output torque
N.m
0.48
0.95
1.91
1.91
3.82
5.73
7.16
Kgf.cm
4.9
9.7
19.5
19.5
39
58.5
73
Rated speed
r/min
3000
Maximum speed
r/min
5000
Rated power rate
kW/s
13.6
29.5
21.8
21.8
47.3
41.8
53.4
Rated current
A rms
1.1
1.8
3.5
1.7
3.3
4.4
5.0
Peak Maximum current
A rms
3.1
5.3
10
5.6
9.7
12.9
14.5
Torque constant
N.m/A±10%
0.16
0.19
0.20
0.39
0.40
0.45
0.50
Kgf.cm/A
1.64
1.88
2.00
3.99
4.05
4.58
5.08
Mechanical constant
ms
0.9
0.7
0.9
0.9
0.6
0.6
0.6
Electrical constant
ms
1.1
1.6
3.3
3.2
3.8
6.0
4.8
Rotor inertia
Gf.cm.s
0.019(0.029)
0.035(0.045)
0.18(0.28)
0.18(0.28)
0.34(0.44)
0.87(1.10)
1.07(1.29)
kW/s
0.019(0.030)
0.035(0.046)
0.19(0.28)
0.19(0.28)
0.35(0.45)
0.89(1.12)
1.09(1.32)
Shaft friction torque
N.m Max
0.02(0.04)
0.04(0.07)
0.04(0.07)
0.08(0.14)
Kgf.cm Max
0.2(0.4)
0.4(0.7)
0.4(0.7)
0.8(1.4)
Play in thrust direction
mm Max
0.2
Allowable radial load
N
78.4
196
196
343
kgf
8
20
20
35
Allowable thrust load
N
39.2
68.6
68.6
98
kgf
4
7
7
10
Encoder
17bit Absolute/incremental
Weight
kg
0.4 (0.6)
0.5 (0.7)
0.9 (1.4)
0.9 (1.4)
1.3 (1.8)
2.2 (3.1)
2.5 (3.4)
Insulation class
Class F
Insulation voltage
AC1500V for 1 min.
Insulation resistance
DC 500V, 100MΩor higher
Environment
Temperature
0~40度
Humidity
85%RH or lower No condensing
Store temperature
-10~85度
Protection class
IP65except the connector, and shaft area
Vibration
49m/s2 5Gor lower
Shock
98m/s210G or lower except shaft
Max. Temp. for sensor area
Encoder 85度以下
About, Induction voltage constant Phase resistance Phase inductance, etc.. Please ask the sales office.
* 1: When it is running at 1/5000 of the rated speed, motor may not run smoothly. When load is 100%, the speed control range become a condition of motor not to stop. When matching with NA20 series motors, speed control range will be 1:3000.
* 2: When the power-supply voltage descends, neither the declared power nor the ratings rotational speed are guaranteed.
* 3: To be changed by the power supply impedance
* 4: Please select the no fuse breaker according to the power supply capacity with enough block capacity for protection.
In regards of specifications, the mentioned values are based on the surroundings temperature 40 after our recommended heat sink is installed. The allowable radial load value is measure by the position of 20 mm from the installation surface. Each values are at the temperature of 20 to 30. The value without a/the common difference is becoming an authorized value.
Heat sink dimensions
50w, 100w
200 x 200 x T12 Aluminum plate
200w,400w
305 x 305 x T12 Aluminum plate
600w, 750w
Servomotor Model
NA80-05
NA80-10
NA80-20
NA80-40
NA80-60
NA80-75
Rated voltage
V
DC24V ±10%
Quiet friction torque
NmMIN
0.32
1.27
2.55
Kgf.cmMIN
3.25
13
26
Consumption power
W
5
9
9.5
Release time
ms MAX
(20)
(20)
(50)
Suction time
ms MAX
(40)
(50)
(80)
Purpose
For holding still
关 键 词: NA80 nikkidenso 日机伺服
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
