产品名称: 日机电装伺服驱动器
型  号: NPS-FIM
品  牌: 日机电装nikki denso
NPS-FIM-400~752 ドライバ仕様
Item Unit NPS-FIM*
-401 -801 -122 -242 -402 -752
Input power   Integrated control power source type Separated control power source type
Main power AC200/220V, 50/ 60Hz, 3 phase
Voltage range
AC180V~AC242V *2
Main circuit method
IPM 4 quadrant bridge sine wave PWM control
Continuous output current(rms) A 3.4 6.4 10.5 15 27 54
nstantaneous output current(rms) A 8.8 17.4 25.6 39 55 98
Instantaneous output torque % 200% (some motor combination 300%)
Control method   Semi-closed loop by encoder feedback
Brake method   Regenerative braking (option: Power regeneration)
Career frequency Hz 10k
(7.5KHz, 10KHz, 15KHz, selectable)
Speed control Speed regulation % ±0.01 (Digital setting, Average value: Temp./0~40℃, Load/ Voltage fluctuation)
±0.05 (Analog setting, Average value: Load/ Voltage fluctuation)
±0.3 (Analog setting, Average value: Temp./0~40℃)
Speed control range   1 : 5000 *1
Field control range   1.3 (Max. speed 6000rpm)/ Rated output (Some motor type: Reduced rated output)
Speed command   External analog speed command: DC0~+10V(±10V/ rated speed),
Input resistance about 20kΩ(resolution: 12bits)
Internal digital speed command: 7 speeds (parameter)
Torque limit   External analog torque limit command (DC voltage): 0~+10V (+3.3V/ Rate torque), Input resistance about 20kΩ(resolution:10bits), Forward/ Reverse: 1 channel, each(total 2ch)
Internal digital torque limit value: Forward/ Reverse: 1 channel, each (parameter)
Torque control Torque command   External torque command (DC voltage): 0~+10V (+3.3V/ Rate torque), Input resistance about 20kΩ(resolution:12bits),
Internal torque command: 3 commands (parameter)
Linearity   ±3% (up to rated toque, repeatability)
Command resolution   1 : 500
Speed limit   External speed limit(DC voltage): Common to External speed command ±10V/ rated speed (common to forward and reverse)
Internal speed limit: 1 point (parameter)
Position control Pulse train control   Max. frequency 1Mpps (at 4 times)
Pulse train command method   Line driver method (directional pulse): Max.250Kpps
Line driver method (90° phase different 2 phase pulse): Max.250Kpps
Open collector method (directional pulse): Max.200Kpps
Pulse train compensation   1/100 ≦ A/B ≦ 100 (A,B : 1~65535)
Position detection   Pulse output 90°phase different 2 phase pulse signal, Marker signal
Output style: Line driver output
Division ratio: 1/N (N=1~32)
Serial communication
  RS-422A, Start/ Stop synchro. Multi-drop wiring is possible, (Communication condition parameter set is possible.) 56kbps
Monitor function
  LCD module (installed),: Status display, Diagnostic display, I/O signal display, Alarm display (last 5 cause history)
Analog monitor: Speed, Torque, Deviation, etc. (Selection by parameter)
Control function
  2 free degree control, FF control, Vibration filter, R2 compensation, Auto. tuning, Non-interacting compensation, Dead time compensation
Protective function
  IPM fault, Over voltage, Under voltage, Over speed, Over load, Encoder fault, Deviation over flow, Communication error, Each data and parameter error , etc.(Last 5 cause history is stored.)
Input signal
  Deviation clear(CLR), Command pulse input inhibit(CIH), Mode select.(MD1, MD2), Local/ Remote(PC), Start(DR), Reset(RST), Emergency stop(EMG※), Speed selection 1~3 (SS1,SS2,SS3), Torque limit(TL), Servo ON(SON), Forward over travel(FOT), Reverse over travel(ROT),
Output signal
  Servo ready(RDY), Alarm(ALM), Warning(WNG), Speed zero(SZ), Positioning complete(PN),
In Speed/ Torque limit(LIM), Brake release(BRK)
Option
  Data Input Unit (MDI unit), Servo ready display, Cables, etc.
Applicable encoder
  6000 ( 2000 ) ppr (Selection by parameter)
Load inertia
  10 times or less of motor rotor inertia
Power capacity *3
kVA 1.1 1.8 3.0 4.7 7.8 15.3
No-fuse breaker (rated current)*4
A 5 10 15 20 30 60
Applicable motor
  NA30-
13F-15
25F-15
NA100-
20F
40F
75F-10
NA30-
50F-15
NA100-
75F
110F-10
NA100-
110F
180F-10
NA30-
110F-15
NA100-
180F
270F-10
370F-10
NA30-
180F-15
NA100-
180F
270F
370AF
370F-10
550F-10
750F-10
Weight
kg 3.8 3.8 7.0 7.0 8.0 12.5
Accessories
  Regenerative resistor
关 键 词: NPS-FIM NCS nikkidenso
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
