产品名称: NIKKIDENSO伺服驱动器
型  号: NPS-FIH
品  牌: 日机电装nikki denso
NPS-FIH-113~373 ドライバー仕様表
Item Unit NPS-FIH*
-113 -153 -223 -303 -373
Input power   Integrated control power source type
Main power AC400/440V, 50/ 60Hz, 3 phase
Voltage range   AC360V~AC484V *2
Main circuit method   IPM 4 quadrant bridge sine wave PWM control
Continuous output current(rms) A 34 46 65 89 115
nstantaneous output current(rms) A 62 81 112 154 210
Instantaneous output torque % 200% (some motor combination 300%)
Control method   Semi-closed loop by encoder feedback
Brake method   Regenerative braking (option: Power regeneration)
Career frequency Hz 10k 7.5k
(7.5KHz, 10KHz, 15KHz, selectable)
Speed control Speed regulation %
±0.01
±0.05
±0.3
(Digital setting, Average value: Temp./0~40℃, Load/ Voltage fluctuation)
(Analog setting, Average value: Load/ Voltage fluctuation)
(Analog setting, Average value: Temp./0~40℃)
Speed control range   1 : 5000 *1
Field control range   1.3 (Max. speed 6000rpm)/ Rated output (Some motor type: Reduced rated output)
Speed command   External analog speed command: DC0~+10V(±10V/ rated speed),
Input resistance about 20kΩ(resolution: 12bits)
Internal digital speed command: 7 speeds (parameter)
Torque limit   External analog torque limit command (DC voltage): 0~+10V (+3.3V/ Rate torque), Input resistance about 20kΩ(resolution:10bits), Forward/ Reverse: 1 channel, each(total 2ch)
Internal digital torque limit value: Forward/ Reverse: 1 channel, each (parameter)
Torque control Torque command   External torque command (DC voltage): 0~+10V (+3.3V/ Rate torque), Input resistance about 20kΩ(resolution:12bits),
Internal torque command: 3 commands (parameter)
Linearity   ±3% (up to rated toque, repeatability)
Command resolution   1 : 500
Speed limit   External speed limit(DC voltage): Common to External speed command ±10V/ rated speed (common to forward and reverse)
Internal speed limit: 1 point (parameter)
Position control Pulse train control   Max. frequency 1Mpps
Pulse train command method   Line driver method (directional pulse): Max.250Kpps
Line driver method (90° phase different 2 phase pulse): Max.250Kpps
Open collector method (directional pulse): Max.200Kpps
Pulse train compensation   1/100 ≦ A/B ≦ 100 (A,B : 1~65535)
Position detection   Pulse output 90°phase different 2 phase pulse signal, Marker signal
Output style: Line driver output
Division ratio: 1/N (N=1~32)
Serial communication
  RS-422A, Start/ Stop synchro. Multi-drop wiring is possible, (Communication condition parameter set is possible.) 56kbps
Monitor function
  LCD module (installed),: Status display, Diagnostic display, I/O signal display, Alarm display (last 5 cause history)
Analog monitor: Speed, Torque, Deviation, etc. (Selection by parameter)
Control function
  2 free degree control, FF control, Vibration filter, R2 compensation, Auto. tuning, Non-interacting compensation, Dead time compensation
Protective function
  IPM fault, Over voltage, Under voltage, Over speed, Over load, Encoder fault, Deviation over flow, Communication error, Each data and parameter error , etc.(Last 5 cause history is stored.)
Input signal
  Deviation clear(CLR), Command pulse input inhibit(CIH), Mode select.(MD1, MD2), Local/ Remote(PC), Start(DR), Reset(RST), Emergency stop(EMG※), Speed selection 1~3 (SS1,SS2,SS3), Torque limit(TL), Servo ON(SON), Forward over travel(FOT), Reverse over travel(ROT),
Output signal
  Servo ready(RDY), Alarm(ALM), Warning(WNG), Speed zero(SZ), Positioning complete(PN),
In Speed/ Torque limit(LIM), Brake release(BRK)
Option
  Data Input Unit (MDI unit), Servo ready display, Cables, etc.
Applicable encoder
  6000 ( 2000 ) ppr (Selection by parameter)
Load inertia
  10 times or less of motor rotor inertia
Power capacity *3
kVA 21 30 41 58 70
No-fuse breaker (rated current)*4
A 50 75 100 125 150
Applicable motor
  NA100-
550F-20H
1100F-10H
NA100-
750F-20H
NA20-
1500-10H
NA100-
750F-20H
1100F-20H
NA20-
2200-10H
NA20-
1500-20H
2700-10H
NA100-
1100F-20H
NA20-
1800-20H
3700-10H
Weight
kg 14.5 27.0 36.0 36.0 63.5
Accessories
  Regenerative resistor
※1. Speed control is defined that in the range a motor does not stop with 100% load.
※2. When power source voltage drops, rated output and rated speed is not guaranteed.
※3. It changes according to power source impedance.
※4. Please choose sufficient shut down capacity type to conduct protective coordinate with power source capacity.
关 键 词: NPS-FIH NIKKIDENSO NPS
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
