产品名称: NIKKIDENSO伺服驱动器
型  号: VPS
品  牌: 日机电装nikki denso
Company profile Contact us CE Center Japanese TOP
VPSシリーズ
Equipped with 7 points positioning function.
VPS series is the multi function servo driver with of useful functions to meet various demands, such as “Feed Forward Torque function” to reduce the Deviation during the motion and “Servo Lock control function” for high level of stability.
By “Feed Forward Torque” control, it is possible to reduce the settling time by setting 2 types parameter of “Inertia” and “viscosity friction”. Also, it also reflects to the Auto Tuning, and it is very functiin.
位置決めポイント7点標準装備
Against the each positioning patterns, it is possible to select 2 patterns of Acceleration / Deceleration, 3 patterns of positioning speed, and 2 patterns of positioning methods (Absolute/Incremental).
原点復帰機能
Since it is the standard Zero Return by using deceleration LS, it has variety of Zero Return functions such as LS zero return without having the deceleration LS, or one revolution short-cut positioning Zero Return that you can set up the discretionary angle as the Zero point if the traveling area of motor is within one revolution.
It is very effective for the vibration control by independently setting the gain changes from 2 items of position loop and the speed loop.
Since it is possible to change the gain at the 2 complete area settings and lower area, you can improve the stability at the stoppage by setting the items that is independently enable to adjust the gain for servo lock.
By using Frequency response and frequency spectral vice versa, you can set the resonance control filter to the resonance points. It is equipped with 5 points of the resonance filters. With this function, you can maximize the potential of servo system and improve the tact time of machine.
onmouseover="MM_swapImage('Image2','','image/VPS_F02.gif',1)" onmouseout=MM_swapImgRestore() shape=POLY coords=582,42,582,4,307,4,291,42 href="#">
onmouseup=" setImg()" href="javascript:;">
  onmouseup=" setImg()" onmouseover="MM_swapImage('Image11','','image/58N.jpg',1)" onmouseout=MM_swapImgRestore() href="javascript:;">
关 键 词: VPS NIKKIDENSO NCR-DC
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
