产品名称: NCS伺服驱动器
型  号: NCS
价  格:
品  牌: 日机电装nikki denso
Company profile Contact us CE Center Japanese TOP
ACサーボコントローラACサーボコントローラ
Processing action of an industrial machine is classified into a/the function element and AC servo controller NCS-FI series is consisted from the elements of primary functions classified into 4 categories. It is composed of the combination of the control unit & servomotor that standardized our original control function. The ranges of motors to fit to NCS-FI are from 11KW to 75KW.
Muti axis control High speed control datacommunication
Fit to world standard network
DeviceNet
Free curve control (NCS-FI6/FS6)
By setting relative position of slave axis to master axis, the free curve motion complying with the master axis can be designed. You can automatically create smooth spline curve movement pattern by using the data editing software and also can make graphical movement pattern as well. Max 16 axis can be controlled, and it can store 50,000 points/500 patterns.
Example: Slave axis rotates.
Slave axis position 1 cycle
For Synchronizing control(NCS-FI4/FS4)
1) You can change the synchronous ratio in real time. The synchronous speed of winding axis of winding machine or feeding axis can be changed one by one.
2) Lag of a relative position between the master axis and slave axis during operation cab be corrected by external signal. The synchronous ratio setting function and the electric shaft function are also available.
Line up wire winding machine
Sectional drive printer machine
Application Traverse control of Conveyer receiving unit, Wire winding machine, Coiling machine, Line up wire winding machine, etc. General Synchronizing control as Cable drawing machine and other various production lines.
Flying Positioning control(NCS-FI3/FS3)
1) Without stopping running work materials, constant length cut and machining can be achieved and machining tact can be remarkably reduced.
2) 50 kinds of continuous machining patterns can be executed in turns. And plural machining combination as of cut and press can be achieved to work materials.
3) By cosine compensation function, in case of vertical blade cutting machine as Rotary shirr, from the beginning of cutting, compensation is addded to get precise vertical cutting.
Example: Flying cutter
Application Carton cutter, Steel plate flying cutter, Cable and pipe cutter, Push/ Pull machining, and flying cutter control of the other production lines.
For Genral Positioning control(NCS-FI1/FS1)
1) High speed, high accuracy, and high performance. Dedicated positioning control, combined of Positioning control and high performance servo control functions.
2) Max.280 points of internal stored data can be used to Program run.
3) Complete close loop control can be achieved by an external encoder (measure/ linear scale).
4) Simple teaching (reads current value by opening current device) can be conducted.
5) Standard spinner function can program Acceleration/ Deceleration time, Rated speed time, and Decal. stop time and easily achieve Run by speed pattern.
Example: Spinner motion
Positioning by angle set
by spinner function
NCS-FCS/FS-1
Basic / Expansion of each type
FI10 / FS10 : Inner Stored data positioning
I/O (Input : 28points / Output : 8points)・・・Basic type
FI12 / FS12 : With I/O expansion board
I/O (Input : 37points / Output : 18points)
FI13 / FS13 : High speed communication type
Remote sequence + Basic type
FI15 / FS15 : Device Net type
Equipped with Device Net to meet to open Network
关 键 词: NCS NCS-FI NIKKIDENSO
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
