Specification:
CPU
Pineview-D/M (Atom D410/D510/N450) processor
System Memory
1x200pin SO-DIMM Socket Dual Channel DDR2 533/677 SDRAM up to 2GB
Chipset
Intel Pineview + ICH8M
BIOS
Award 16 MB BIOS
Ethernet
One Realtek PCI-E Gigabit LAN
Second Realtek PCI-E Gigabit LAN (Option)
Audio
Built-in Intel® High Definition Audio
Audio Codec:VIA VT1708A HDA Codec
Audio Interface:Mic-in, Line-in, Line-out
Display
VGA
One Channel 18bit LVDS
I/O Interface
Chipset:Winbond W83697HG
Serial Port (RS232/422/485):2 x External D-SUB 9-pin Connectors for COM1/COM2)
Serial erial Port (RS232):4 x Internal Box Header for COM3/COM4/COM5/COM6) (Option)
Universal Serial Bus 2.0:10 (4 x Front, 4 x Rear, 2 x Internal)
PS/2:One 2L Mini-Din Connector for Keyboard and Mouse
Compact Flash:1 x Compact Flash connector
SATA:2 x SATA II
GPIO:4 in / 4 out
IDE:One 44pin Box Header for IDE Device
Watchdog Timer
Reset : Generates system reset; 256 levels
H/W Status Monitor
Monitoring CPU temperature, and voltage status.
Expansion Slot
One PCI Slot
Dimensions
170 mm (L) x 170 mm (W) -> ATX Power
210 mm (L) x 170 mm (W) -> 12V/5A, 60Watt DC Adaptor
