Specification
Hardware
CPU
Intel Celeron M/ Pentium M Processor
Chipset
North Bridge: Intel 852GM
South Bridge: ICH4(82801DB)
Memory
Support for up to 1GB of DDR 266/200
1x200pin DDR SO-DIMM Socket
Bios
Award system BIOS
4MB Flash ROM
Support " Power On" after power failure
Support " Wake on LAN"
Display
Internal Graphics (ICH4)
Max 32MB Shared Memory
1x VGA connector
1 x DVI connector (Option)
Support Dural Display (VGA+DVI)
Audio
AC97 2.0 CODEC compatible
1 x Mic-in, 1 x Line-in, 1 x Line-out
Ethernet
RTL 8100C (10/100 Mbps)
1 x RJ-45 connector
Support Second Ethernet ( Option)
I/O Interface
Compact Flash connector: 1 x Type-II (Primary)
IDE connector: 1 x 44 pin Ultra ATA 33/66/100 (Secondary)
PS/2 Port: 1 x Keyboard, 1 x Mouse
USB 2.0 Port: 2 x Front, 4 x Back
Parallel Port: 1 x D-Sub 25pin connector ( SPP/ EPP/ ECP )
Serial Port: 2 x 1L D-Sub 9pin connector ( RS232)
Support third and forth Serial port ( Option )
Expansion Slot: 1 x Min PCI ( Option )
Power
DC 12V / 5A, 60W External Power Adapter
Mechanical and Environment
Dimensions
250mm ( L ) X 195mm ( W ) X 50mm ( H )
Housing
Aluminum Case
Temperature
Operating: 0 C - 40 C
Storage: -20 C - 80 C
Relative Humidity
0% - 90 %
Odering Information:
CPU
Intel Celeron M 600MHz 512K Cache (BGA, Fanless)
Intel Celeron M 1GHz 0 Cache (BGA, Fanless)
Intel Celeron M 1.3GHz 512K Cache (PGA, Fan)
Intel Celeron M 1.5GHz 1M Cache (PGA, Fan)
Intel Pentium M 1.6GHz 1M Cache (PGA, Fan)
Intel Pentium M 1.8GHz 2M Cache (PGA, Fan)
Intel Pentium M 2.0GHz 2M Cache( PGA, Fan)
Option:
Metal Mounting Kit (VESA Standard)
Internal Wireless Network Card (Option)
