Specifications
CPU
Intel® N270 Atom8482; processor
System Memory
l 1 x 200-pin SO-DIMM Socket Support Dual Channel DDR2 400/533/667 SDRAM up to 1GB
Chipset
Intel® 945GSE + ICH7M
BIOS
l Award system BIOS
l Supports “Power on” after power failure
l Supports Wake on LAN
l 8MB flash ROM
Ethernet
l Onboard Two Realtek RTL8111C Gigabit LAN
Audio
l Built-in Intel® High Definition Audio
l Audio Codec:VIA VT1708A HDA Codec
l Audio Interface:Mic-in, Line-in, Line-out
Display
l Intel® Graphics Media Accelerator (GMA) 950,
l VGA or DVI-I / One Channel LVDS
I/O Interface
l Chipset:Winbond W83627HG
Serial Port:1 x External D-SUB 9-pin Connectors for COM1(RS232/422/485), 1 x Internal pin header for COM2(RS232)
Universal Serial Bus 2.0:6 x External USB Connector
PS/2:One Mini-Din Connector for Keyboard and Mouse
Compact Flash:1 x Compact Flash connector
SATA:2 x SATA II
GPIO:4 in / 4 out
SSD:One CompactFlash Type I/II socket
Watchdog Timer
Reset : Generates system reset; 256 levels
H/W Status Monitor
Monitoring CPU temperature, and voltage status.
Expansion Slot
One PC-104+ slot
System Power
Adaptor (12V/5A)
Environment
System Level Operating Temperature: 0oC ~40oC
Storage Temperature: -20oC ~80oC
Dimensions
166 mm (L) x 122 mm (W)
