Specification
Hardware
CPU
- Intel® Core 2 Duo/ Core Duo/ Core Solo mobile Processor
Chipset
- North Bridge: Intel 945GME
Memory
- 2 x 240pin DIMM Socket Support Dual Channel DDR2 533/667 SDRAM up to 4GB
BIOS
Display
- Intel 945GME GMCH Integrated Graphic Media Accelerator 950, supports 224MB video memory
- Resolution: 2048*1536 @32bpp (@60Hz)
- LVDS: 18/24-bit Dual-channel LVDS
Audio
- Chipset: Intel 82801GM ICH7M
- Codec: Realtek ALC888 5.1 + 2 Ch Audio Codec supports 2 independent audio streams
- 1 x Mic-in,1 x Line-in,1 x Line-out
Ethernet
- Controller: Marvell 88E8053
- 2 x Gigabit Ethernet Port
- Wireless LAN (through Mini-PCI slot, Optional)
I/O Interface
- SSD: 1 x Type II Compact Flash Connector
- IDE connector:1 x 40pin IDE Connector
- SATA: 2 x Serial ATA Connector
- PS/2 Port :1 x Keyboard, 1 x Mouse
- USB 2.0 Port:2 x Front, 4 x Rear
- Serial Port:3 x 1L D-SUB 9pin connector (2 Powered COM)
- DIO: 8-bit General Purpose I/O for DI & DO
- Expansion Slot: 1 * PCI, 1 * Mini PCI
Power
- 125W Internal Power Supply
- Reset: 1 sec ~ 255 min. and 1 sec or 1 min/step
- Monitoring CPU temperature, voltage, and cooling fan Status.
- Auto throttling control when CPU overheats
Mechanical and Environment
Dimensions
- 310mm ( L ) X 255mm ( W ) X 100mm ( H )
Housing
Temperature
Relative Humidity
Odering Information:
DT-B1104S
- Socket 478 Intel Core 2 Duo/ Core Duo with Dual LAN, 6 USB, Mini-PCI x 1, PCI x 1 Expansion
