HMM-AV01ϵÁÐÖÇÄÜÊýÏÔ±í HMDTY Series Digital Panel Meters רÓÃÀËÙ±í (¸Ö³§Ö¸¶¨ÅäÌ×É豸£© |
ÌØµã£ºFEATURES ¡Ñ ±¾²úÆ·ÌØ±ðÊÊÒËÓëͨÓÃ±äÆµµ÷ËÙÆ÷ÅäÌ×ʹÓã¬Óë±äƵÆ÷Ä£ÄâÁ¿ÐźÅÊä³ö¶ËµÄµçѹ0-10V»òµçÁ÷Êä³ö¶Ë4-20mAÁ¬½Ó£¬½«ÐýתÁ¿¾¹ýÖÇÄÜÊýÏÔ±íת»»³ÉËùÐè¶ÔÓ¦µÄÈçÀËÙ¶È¡¢ËÙÂÊ¡¢Á÷Á¿¡¢ÆµÂÊ¡¢Ðг̵ÈËùÐèÒª»ñµÃµÄ¶ÔÓ¦ÊýÖµ¡£²¢ÇÒ¿Éͨ¹ýÊýÏÔ±íµÄÍâÖõ÷½Ú¶ËÐÞÕýÏÔʾ¾²²îÖµºÍ±ÈÀý´ø£¬È·±£ÏÔʾ¾«¶È¡£±¾²úÆ·ÒѾÊÇÌæ´ú½ø¿ÚÒÔ¼°¹úÄÚС·½Å÷Á¬Öý»úϵͳµÄÊ×Ñ¡ÀËÙ±í¡£ ¡Ñ²úÆ·ÊÊÓÃÓÚ¸÷ÖÖ¾ßÓÐÏßÐÔÊä³öÌØÐԵĴ«¸ÐÆ÷»òÆäËû²âÁ¿É豸£¬Èçµçѹ¡¢µçÁ÷¡¢Ñ¹Á¦¡¢ÖØÁ¿¡¢ËÙ¶È¡¢ÆµÂÊ¡¢Î¶ȡ¢Êª¶ÈµÈµÄ²âÁ¿ÏÔʾ The meter can be used with linear output features sensor or other measuring as measuring and display of pressure, weight, speed, frequency and humidifies. ¡Ñ ±ê׼ͨÓÃÐÔ±í¿Ç£¬Ìå»ýСÇÉ Current watchcase,volume delicate ¡Ñ ²âÁ¿×¼È·£¬ÐÔÄܿɿ¿ Measuring precision,performances reliable ¡Ñ ×î´óÏÔʾ·¶Î§¡À1999 Max,display range ¡À1999 ¡Ñ ÊäÈ뷽ʽ: A. µçÁ÷4-20 mA (0-20 mA) »ò¸ù¾ÝÓû§ÒªÇó¡£ B. µçѹ1-5V£¬0-5V£¬0-200 mV»ò¸ù¾ÝÓû§ÒªÇó¡£ ±¾²úÆ·ÊÇÔHMDTYÐͺűíµÄÉý¼¶²úÆ·£¬µ÷½ÚÐÞÕûÓÉÄÚÖÃʽ¸Ä³ÉÍâÖ÷¸ÇʽÒÔ±ãÏÖ³¡µ÷Õû |
Ò»£® ¼¼Êõ²ÎÊý SPECIFICATIONS |
ÊäÈ뷽ʽ Input mode |
µçÁ÷: Ampere : 4-20 mA (0-20 mA) µçѹ: Voltage1: 1-5V£¬0-5V£¬0-10V£¬0-200 mV |
¾« ¶È Accuray |
¡À0.5£¥F.S ¡À 2Digit (23¡æ¡À5¡æ) |
A/Dת»» A/D onverter |
Ë«»ý·Ö A/D ת»» Dual slope A/D conversion |
²ÉÑùËÙ¶È Sampling speed |
Ô¼ 2.5´Î/Ãë Abt2.5/s |
×î´óÏÔʾ Max.Display |
1999¿ÉÉ趨СÊýµã Can set decimal point |
ÏÔ Ê¾ Display |
ºìÉ«ÊýÂë¹Ü¸ß14.2mm red LED 14.2mm H |
ÏûºÄ¹¦ÂÊ Power consumption |
¡Ü4W |
ʹÓÃÎÂ¶È Operating temperature |
0¡æ - 55¡æ |
µç Ô´ Aux.Power supply |
AC 220V / DC 24V ÈÎÑ¡ |
ÖØ Á¿ Weight |
350g |
ÍâÐγߴç Outside dimension |
48mm(H) ¡Á 96mm(W) ¡Á 112mm(D)DIN |
¿ª¿×³ß´ç Perforate dimension |
92mm(W) ¡Á 44mm(HD)DIN |
¶þ£® ¶Ë×ÓÁ¬½Ó CONNECTION DIAGRAM |
AC½»Á÷µçÔ´¹©µç |
DCÖ±Á÷µçÔ´¹©µç |
Èý£® ÍâÐμ°±íÅÌ¿ª¿×³ß´ç THE OUTSIDE DIMENSIOS |
ÕýÃæ______________________²àÃæ ______________________¿ª¿× |
Ö÷Ãæ°åÄÚ²à¿ØÖÆÃæ°å |
ËÄ£® ×¢ÒâÊÂÏî CAUTIONS 1£®ÊÊÒËʹÓû·¾³Î¶È0¡æ-50¡æ£¬Ïà¶Ôʪ¶È85%ÒÔÏ¡£ Use in ambient temperatures of 0¡æ to 50¡æ,humidifies 85%R.H. 2£®ÊäÈëµ¼ÏßʹÓÃÆÁ±ÎÏ߽Ϻá£Input wire use the shielded wire. 3£®±¾Í¨ÓÃÊý×ÖÏÔʾ±íÓжàÖÖ¹©µç·½Ê½ºÍÊäÈ뷽ʽ£¬ÔÚ°²×°Ê±ÇëÌØ±ð×¢ÒâУ¶ÔËùÑ¡ÒDZíÊÇ·ñÓëʵ¼ÊÒªÇóÏà·ûºÏ¡£ |
Î壮 ˵Ã÷ NOTES HMM-AV01ÐÍÖÇÄÜͨÓÃÊý×ÖÏÔʾ±íʹÓ÷¶Î§·Ç³£¹ã£¬ÇëÔÚ¶©¹ºÊ±Îñ±ØÏêϸ˵Ã÷ÒªÇó£¬ÈçÑ¡ÓõçÔ´Ö±Á÷24V¹¤×÷£¬ÊäÈ뷽ʽÊÇ4-20mA,¶ÔÓ¦Êý×ÖÏÔʾΪ0-150.0 £¬ÏÔʾֵµ¥Î»ÊÇM/Min¡£ÒÔ±ãÎÒÃÇÕýÈ·ÎÞÎ󵨼´Ê±Ìṩ¸øÓû§£¬Ð»Ð»ºÏ×÷£¡
