NovAtel SPAN-FSAS½ôñîºÏ×éºÏµ¼º½
NovAtel SPAN-FSAS½ôñîºÏ×éºÏµ¼º½ÊDzÉÓÃGNSSÓë¹ßÐÔ²âÁ¿µ¥Ôª(IMU)½ôñîºÏÔÀíµÄ×éºÏµ¼º½ÏµÍ³£¬²ÉÓÃNovAtel µÄSPAN® ¼¼Êõ£¬Í¬²½´¦ÀíNovAtel ¸ß¾«¶ÈGNSS Êý¾ÝºÍiMAR FSAS Êý¾Ý£¬½âËãλÖÃ×Ë̬¡£½«IMUºÍ¾«×¼µÄGNSS¼¼ÊõÇÉÃîÅäºÏ£¬¿ÉÑ¡¹¦ÄܶࡢӦÓÃÁé»î£¬Æä¾«¶È¸ßÓÚµ¥´¿GNSSϵͳÊý±¶£¬´Ó¶øÌṩ¸üÎȶ¨Á¬ÐøµÄ3DλÖá¢ËٶȺÍ×Ë̬µÈÊý¾Ý£¬¼´Ê¹GNSSÐźŶªÊ§£¬Òà¿É±£Ö¤Ò»¶¨Ê±¼äÄڵĿÉÓÃÊý¾ÝÊä³ö¡£
NovAtel SPAN-FSAS½ôñîºÏ×éºÏµ¼º½²ÉÓõ¹úiMAR¹«Ë¾µÄ¸ß¾«¶ÈIMU£¬Ä¿Ç°NovAtel µÄFlexPak6™»òProPak6™¼¯³ÉÁË×éºÏµ¼º½½âËã¡£´ÓIMU-FSASµÄ¹ßÐÔ²âÁ¿Êý¾Ý·¢Ë͵½GNSS½ÓÊÕ»ú½øÐнâË㣬GNSS + INSµÄλÖÃ,ËٶȺÍ×Ë̬Êä³öËÙÂʸߴï200Hz¡£ÔÚ½µØÓ¦ÓÃʱ£¬ÏµÍ³»¹¿ÉÍâ½ÓÂÖËÙ´«¸ÐÆ÷¡£
ÌØµã£º Ó¦Óãº
Á¬Ðø¡¢Îȶ¨µ¼º½ ÔØÌå¿ØÖÆ
GNSS/INS½ôñîºÏ ½µØµ¼º½
Êý¾Ý¼Ç¼£¬×î´óÖ§³Ö4G ´¬Ôؽ¢ÔØ
µØÃæÓ¦ÓÃʱ¿ÉÍâ½Ó³µÂÖ´«¸ÐÆ÷ º½¿ÕÓ¦ÓÃ
ƽ̨Îȶ¨
¶¨Î»¾«¶È£¨RMS£©
µ¥µãL1
1.5m
µ¥µãL1/L2
1.2m
SBAS
0.6m
DGPS
0.4m
RTK
RTK¾«¶È
1cm+1ppm
RTK³õʼ»¯Ê±¼ä
<10 s
RTK³õʼ»¯×¼È·¶È
>99.9%
ËٶȾ«¶È£¨RMS£©
0.03m/s
ʱ¼ä¾«¶È£¨RMS£©
20ns
½ÓÊÕͨµÀ
240ͨµÀ
ÎÀÐÇϵͳ
GPS L1, L2, L2C, L5
GLONASS L1, L2, L2C
Galileo E1, E5a, E5b, AltBOC
BeiDou B1, B2
SBAS
QZSS L1, L2C, L5
L-Band
²âÁ¿¾«¶È
GPS
GLO
L1 C/AÂë
4cm
8cm
L1ÔØ²¨Ïàλ
0.5mm
1mm
L2 P£¨Y£©Âë
8cm
8cm
L2ÔØ²¨Ïàλ
1mm
1mm
L2CÂë
8cm
8cm
L2CÔØ²¨Ïàλ
1mm
1mm
L5Âë
3 cm
L5ÔØ²¨Ïàλ
0.5 mm
Æô¶¯Ê±¼ä
ÀäÆô¶¯
50 s
ÈÈÆô¶¯
35 s
Êý¾Ý¸üÐÂÂÊ
λÖÃ
100Hz
²âÁ¿
100Hz
º½Ïò¾«¶È£¨Ë«ÌìÏßÅäÖã©
0.40° @0.5 m »ùÏß
0.20° @1.0 m »ùÏß
0.10° @2.0 m»ùÏß
IMUÐÔÄÜ
ÍÓÂÝÊäÈ뷶Χ
±450°/s
ÍÓÂÝÁãÆ«
<0.75deg/hr
ÍÓÂÝÆ«ËÙ±ÈÀýÒò×Ó
300ppm
½ÇËæ»úÓÎ×ß
0.1deg/√hr
¼ÓËٶȼÆÁ¿³Ì
±5g
¼ÓËٶȼÆÏßÐÔ¶È/±ÈÀýÒò×Ó
300ppm
¼ÓËÙ¶È¼ÆÆ«²î
1.0mg
IMUÎïÀíµçÆøÖ¸±ê
Ìå»ý
128mm×128mm×104mm
ÖØÁ¿
2.1Kg
¹¦ºÄ
16W£¨×î´ó£©
ÊäÈëµçѹ
+11V¡«+34V
ÊäÈë/Êä³ö½ÓÍ·
MIL-C-38999-III£¬22Õë
IMU»·¾³ÊÊÓ¦ÐÔ
¹¤×÷ζÈ
-40¡æ¡«+71¡æ
´æ´¢Î¶È
-40¡æ¡«+85¡æ
ʪ¶È
95%ÎÞÀäÄý
MTBF
35,000h
ͨѶ½Ó¿Ú
RS-232/RS-422
3
IMU½Ó¿Ú
1
USB2.0Device
1
USB2.0Host
1
Íø¿Ú
1
CAN×ÜÏß
2
EventÊäÈë
4
EventÊä³ö
4
À¶ÑÀ
1
Wi-Fi
1
ÎÞÏßͨѶGPRS/HSPA
¿ÉÑ¡
ÎïÀíµçÆøÖ¸±ê
Ìå»ý
190mm×185mm×75mm
ÖØÁ¿
1.79Kg
¹¦ºÄ
3.5W
ÊäÈëµçѹ
+9V¡«+36V
»·¾³ÊÊÓ¦ÐÔÖ¸±ê
¹¤×÷ζÈ
-40¡æ¡«+75¡æ
´æ´¢Î¶È
-40¡æ¡«+95¡æ
ʪ¶È
95%ÎÞÀäÄý
Õñ¶¯£¨¹¤×÷£©
Ëæ»ú MIL-STD-810 514.6 Category 24, 20-2000Hz/ 7.7 g 1 hr/axis
ÕýÏÒ IEC 60068-2-6 (5 g),10-2000 Hz
¼ÓËÙ¶È£¨¹¤×÷£©
MIL-STD 810G, Method 513.6
Procedure II (16 g)
³å»÷£¨·Ç¹¤×÷£©
MIL-STD-810G, 516.6 , procedure 1,
40 g 11 ms terminal sawtooth
ϵͳÐÔÄÜÖ¸±ê£º£¨Ëø¶¨×´Ì¬ºÍÎÀÐÇÊ§Ëø×´Ì¬£©
Ê§ËøÊ±¼ä
¶¨Î»Ä£Ê½
λÖÃÎó²î
m£¨RMS£©
ËÙ¶ÈÎó²î
m/s£¨RMS£©
×Ë̬Îó²î
°£¨RMS£©
ˮƽ
´¹Ö±
ˮƽ
´¹Ö±
ºá¹ö
¸©Ñö
º½Ïò
0s
RTK
0.020
0.050
0.020
0.010
0.008
0.008
0.023
SP
1.200
0.600
0.020
0.010
0.009
0.013
0.024
PP
0.010
0.015
0.020
0.010
0.008
0.008
0.012
10s
RTK
0.130
0.060
0.026
0.010
0.010
0.010
0.025
SP
1.340
0.670
0.035
0.011
0.014
0.014
0.026
PP
0.020
0.020
0.020
0.010
0.008
0.008
0.013
60s
RTK
3.500
0.320
0.135
0.015
0.015
0.015
0.040
SP
4.440
0.870
0.151
0.015
0.018
0.018
0.040
PP
0.130
0.050
0.030
0.020
0.010
0.010
0.016
ÈçÓÐÀàËÆÐèÇó£¬ÇëÁªÏµÆßάº½²â(֤ȯ´úÂ룺430088)»ÆµË¾ü£¬¸øÄúÍÆ¼ö×î¼Ñ½â¾ö·½°¸¡£
