Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ²àװʽ´¬ÓôÅÐÔ¸¡×ÓҺλ¼Æ
²úÆ·Ãû³Æ£º ²àװʽ´¬ÓôÅÐÔ¸¡×ÓҺλ¼Æ
ÐÍ ºÅ£º UHZ-511/512
UHZ-51ϵÁд¬ÓôÅÐÔ¸¡×ÓҺλ¼Æ MARINE MAGNETIC FLOAT TYPE LEVEL GAUGE
¡ô¸ÅÊö GENERAL
   UHZ-51ϵÁдÅÐÔ¸¡×ÓҺλ¼ÆÊÊÓÃÓÚ½¢´¬¼°ÆäËü¹¤ÒµÉ豸ÖжԲչñÄÚ½éÖʵÄҺλ(»òÒ×Äý¹ÌÁ÷¶¯ÐÔ²îµÄ½éÖÊҺλ)½øÐвâÁ¿ºÍ¿ØÖÆ¡£
   UHZ type magnetic float type level gauge can be used to measure and control level of the tank inship and other industrial
instrument.
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
¹æ¸ñÐͺŠModel:UHZ-511/512/515
²âÁ¿·¶Î§ Measuring range:500(ÖÁto)6000mm(¿ÉÑ¡option)
²âÁ¿¾«¶È Measuring accuracy:±10
°²×°ÐÎʽ Mounting type£ºUHZ-511/512²àװʽHorizontal mounting
                       UHZ-515¶¥×° Top mounting
½éÖʱÈÖØ Medium gravity:≥0.5
½éÖÊÕ³¶È Medium viscosity:UHZ-512(≤0.02pa.s) UHZ-515(≤0.01pa.s)
¹¤×÷ÎÂ¶È Working temp:≤350¡æ
¹¤×÷ѹÁ¦ Working pessure(MPa):UHZ-511/512(≤1.0(1.6¡¢2.5¡¢4.0£©MPa)
                              UHZ-515(≤2.5MPa)
ÕôÆûѹÁ¦ Steam pressure:UHZ-512(≤0.8MPa)
½Ó¿Ú·¨À¼ Connection flange:GB2506-89DN20 PN1.0 GB2506-89 DN125 PN1.0
±¨¾¯¿ª¹Ø Alarm switch:AC:220V 2A  ±£³ÖÐÍ Retaining type(¿ÉÑ¡Option)
Ô¶´«ÐźŠOutput signal:DC24V 4-20mA  (¿ÉÑ¡Option)
ÅäÌ×·§ÃÅ SUPPORTING THE VALVE:½ØÖ¹·§ Shut-off valve /×Ô±Õ·§ Self-close valve /Çò·§ Ball valve
¹«Ë¾Ãû³Æ£º ÁÉÑôË«ÐËÒDZíÓÐÏÞ¹«Ë¾
µç »°£º 0419 2308848 / ±ßÖÒÎä
ÊÖ»ú£º 13224196713
µØ Ö·£º ÁÉÄþÊ¡ÁÉÑôÊÐÌ«×ÓºÓÇøÌúÎ÷¹¤ÒµÔ°µØÖÊ·9ºÅ
ÓÊ ±à£º 111000
Ö÷ Ò³£º http://sxcyyb.com
  • Éù²¨Çå»ÒÆ÷
  • µç½Ó´¥ÒºÎ»¿ØÖÆÆ÷
  • ´¬ÓÃѹÁ¦Ê½ÒºÎ»±äËÍÆ÷
  • 26G¸ßƵÀ×´ïÎïλ¼Æ
  • µ¼²¨À×´ïÎïλ¼Æ
  • ³¬Éù²¨ÒºÎ»¼Æ
  • Òô²æÊ½Îïλ¿ª¹Ø
  • ¶¥×°Ê½´¬ÓôŸ¡×ÓҺλ¼Æ
  • ´¬ÓÃѹÁ¦±äËÍÆ÷
  • ´¬ÓÃζȴ«¸ÐÆ÷
